    Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!
    musicbgmsynackguide
    165 Posts 59 Posters 126.3k Views
    • WarC0zesW
      WarC0zes
      @Naprosnia Yes, exactly. With fade effect enable.
      RetroPie v4.5.1 • RPi3 Model B • NorthPada 5V 3A • 128GB SanDisk Ultra Cat.10 microSDXC • 1 x Logitech Wireless Desktop MK250 • 1 x Qanba Q4RAF USB Arcade joysticks • 1 x PS4 Dualshock4 v2 controller • 1 x Mayflash Dolphinbar + Nintendo WiiMote.
      • N
        Naprosnia @WarC0zes
        @WarC0zes fixed now. I put an extra option on RetroPie-BGM-Player / BGM Update menu, to reinstall everything. So if you need to reinstall it, simply go to update and select reinstall.
        But for now you need to reinstall again manually.
        WarC0zesW 1 Reply Last reply Reply Quote 0
        • WarC0zesW
          WarC0zes @Naprosnia
          @Naprosnia It's good the volume stays at 100% now. Thanks.
            Sibby
            @Naprosnia Hey man, I love your implementation of this. Ultra noob friendly and integrated into the config menu for fine adjustments. I have a small idea/request. I like to display launch art, as well as have the BGM fade effect set. But currently they work independent of each other. Currently: Launch Game > Music Fades > Then launch art is displayed > game starts. I think it would be great if it could work like: Launch Game > Launch Art is displayed AS music is fading > game starts.
            I don't know if that's possible but you got a donation coming your way if you can :) Either way, keep up the great work!
            cyperghostC N 2 Replies Last reply Reply Quote 0
              cyperghost @Sibby
              @Sibby said in Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!:
              That's a gentle deal ;) But you can donate here, too
                Sibby @cyperghost
                @cyperghost The donation has been made! :) This forum has been vital for working through issues I've come across. It's folks like yourself the help keep a vibrant community. Thanks!!!
                  cyperghost @Sibby
                  @Sibby you can try to add an & just beind the shell script call in runcommand-onstart.sh
                  I have done the same for the on end call as I introduced this feature here go this thread
                  • N
                    Naprosnia @Sibby
                    @Sibby Hello, today i will launch a new version with support to music emulation. As you mention, in this version the music fades will art is show.
                      cyperghost @Naprosnia
                      @Naprosnia may I ask which application do you use to play emulated soundtracks? Can you extend to play module files too?
                      • N
                        Naprosnia @cyperghost
                        @cyperghost hello, check audacious application files support. When i release the new version i post the files supported for BGM Player. I know that audacious support some module files, but i need to "unlock" it on bgm player. Google for audacious supported files, if you see some of your interest, tell me and i add its support to bgm player.
                        Because of the way i implemented the application on bgm, i need to add the file type to the bgm player settings so it can manage to play it.
                        • N
                          Naprosnia
                          Version 2 released. Go to https://github.com/Naprosnia/RetroPie_BGM_Player and check all the new stuff.
                          Tomorrow i record a new video.
                          • N
                            Naprosnia
                            New video:
                              @Naprosnia Yes I see audacious is your new player now. It seems very versatile. How is the CPU load?
                              • N
                                @cyperghost, very lightweight. I try with Game Music Emulation Library compiled by me, and it lags a little. But with audacious, it works very well.
                                • WarC0zesW
                                  WarC0zes
                                  @Naprosnia We can update directly from the "update" option or we have to reinstall the script ?
                                    @Naprosnia There is still space for some software tweaks for sure but all in all ... well done!
                                    @WarC0zes Yes, the update script wasn't changed to much so the update via menu should work
                                    • WarC0zesW
                                      WarC0zes
                                      @Naprosnia Really cool the version 2.0, great job. Thanks.
                                        Sibby
                                        @Naprosnia 2.0 is awesome! I don't know how it all works but somehow this should be considered for an optional RP package. Oh, enjoy your burger too :)
                                          gumpy123
                                          Here's an interesting one, I changed the ES boot logo just fine, I removed the ES boot logo with the --no-splash tag but you cant have background music and not have the ES boot screen, it only works if I've got both. It does however work if i go into the setup.sh file and move the emulationstation --no-splash to the top and move the omx bgm music player to the bottom. I get no ES splash but music dont work. Unless it's the other way around then it works
                                          • N
                                            Naprosnia @gumpy123
                                            @gumpy123 hello, You use my version of bgm player? Can you post here autostart.sh content? I use omx splashscreen and the --no-splash for ES and everything works.
