    Mayflash Sega Saturn Adaptor 2nd controller not recognised
    mayflashsaturncontroller help
    27 Posts 5 Posters 5.9k Views
      stevethefish76 @mitu
      @mitu Holy crap, THANK YOU SO MUCH for helping me with this! I had the exit input set to NUL but I didn't notice that there was another line, which was confusing the emulator. This is what was screwing things up for me! The Saturn emulator works great (and on my Linux desktop and not a RasPi, the emulation seems perfect to my untrained eye), but that wasn't the problem. Now that the start button no longer exited games on the other Sega emlators, I was able to load the core remap button config file to use with the Megadrive, Mega CD, and 32X. I had this all working fine with the Nitiumi fake Saturn pad, but that went kaput as some users on Reddit warned me would happen. Now everything is working fine. Once again, THANK YOU! I'll revisit this thread later if I can't get the analog pad working properly with the process described above.
        stevethefish76
        I caught an error in my config file. I've come back to the Saturn this evening and this time I tried playing Street Fighter Zero 3. The Saturn's Z button is properly mapped to be the "L" button on a standard controller. This is the strong punch. For some weird reason, the config I provided above had two lines which I have no idea where they came from.
        Totally weird. I didn't notice this earlier because I've been mainly playing shmups. I still need to try to get the second controller to work.
          Something happened, somehow, without me going into the controller configuration mode, which affects the hotkey ONLY for the Saturn Beetle emulator while using either my Saturn D-pad or my Virtua Stick via the Mayflash converter. I am using Retropie ver. 4.8.2 on my Linux Mint desktop PC (x86 architecture, 64bit) rather than a RasPi. Below is the input config file. Two things though:
          input_enable_hotkey_btn = "7" (this is the Start Button on the Saturn controller)
          input_menu_toggle_btn = "2" (While the Start Button is pressed, pressing the X button on the controller brings up the Retroarch menu.
          This works for FBA, Megadrive, 32X, SegaCD, anything. Except somehow, it has stopped working for the Saturn emulator. What brings up the Retroarch menu with the Saturn menu is pressing Y and Z together.
          So Y should be btn="2" and Z should be btn="10" unless I am mistaken. I do have a core remap enabled for the MD, MCD, and 32X, but it is not loaded for the Saturn emulator. What could be the problem? (Again, the hotkey is the same as Start on purpose because it's how I want to bring up the menu in combination with the other button. I just don't get why it's going to completely different buttons.)
          input_device = "Generic X-Box pad"
          input_driver = "udev"
          input_l_btn = "9"
          input_up_btn = "h0up"
          input_up_btn_label = "Stick Up"
          input_left_btn = "h0left"
          input_left_btn_label = "Stick Left"
          input_r2_btn = "5"
          input_right_btn = "h0right"
          input_right_btn_label = "Stick Right"
          input_l2_btn = "4"
          input_l2_btn_label = "L"
          input_r_btn = "10"
          input_y_btn = "2"
          input_x_btn = "3"
          input_down_btn = "h0down"
          input_down_btn_label = "Stick Down"
          input_start_btn = "7"
          input_start_btn_label = "Plus"
          input_b_btn = "0"
          input_a_btn = "1"
          input_exit_emulator_btn = "nul"
            Something happened, somehow, ...
            You probably reset your configuration for the saturn system or disabled the hotkey from the RetroArch menu. Just revert to the default configuration by deleting /opt/retropie/configs/saturn/retroarch.cfg and then re-installing the Saturn Beetle emulator. This will generate the default configuration, which should have the hotkey enable button added. Don't start the emulator until you re-install it, otherwise the configuration file will not be correctly generated.
              @mitu Would I have to remove the emulator first before re-installing it? Or is simply removing that config file enough?Thanks.
                mitu Global Moderator @stevethefish76
                @stevethefish76 No, you don't need to remove it.
                  @mitu Thanks! It worked. I didn't have to re-install the lr-beetle-Saturn emulator, but rather run an update after deleting the config file. thanks!
