    Pi in a Dreamcast VMU Build - WIP
    buildprojecthandheldvmudreamcast
    157 Posts 7 Posters 96.5k Views
    • mooseprM
      moosepr @Arvester
      @Arvester yeah it actually says 6-15VDC so that might need a spot more boosting, and the extra board for the composite decoder chip too might eat up some space.
      you can actually run the cheepo 1.44" screens straight to the pi with just a resistor for the backlight if your soldering is up to it (excuse the cat hair in the photo!!)
      cat hair city!!
      anything to save a few mm :P
      want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
      • ArvesterA
        Arvester
        I have finally received my screens, unfortunately there's only one v1.1, the other one is something I never ordered (I ordered the two same) , there's a HUGE chip on the pcb and there is soldering points at the two ends, taking much more place. I can't use this. I didn't noticed at first glance, and I opened the wrong one first, 3$ lost ^^
        Oh, and there's no problem with cat hair, I'm invaded too ^^
        mooseprM 1 Reply Last reply Reply Quote 0
        • mooseprM
          moosepr @Arvester
          @Arvester that's a pain, nothing worse try waiting for weeks for bits and they arrive wrong 😞
          Black rug and white cat was never a good idea 😛
          • ArvesterA
            Arvester
            USB charging port, and homemade home button.
            Final mock-up (I broke the screen when I tried to take the pcb apart, I need to buy another one)
            Pi logo was meant to go there !
            Everything fits, room for battery is about 30x30x5mm.
            Next step is solder everything, as I'm not sure about the pinout for the screen, I didn't start yet.
              obsidianspider @Arvester
              @Arvester Looks great! Which battery are you going with? I'm thinking about picking up this 500mAh one from Adafruit which is 36mm x 29mm x 4.75mm once they get more Pi Zero Ws in stock (I want to make the most of their high shipping minimum).
              • ArvesterA
                Arvester
                I'll probably take this one too, those I was looking for on eBay are too thick.
                Also, I would not recommand to put the home button in the corner as I chose, it prevents the VMU to close properly. I had to modify it, the cap is now glued to the top part of the shell, and I cut some bits of the shell's lower part so I can slide it inside the cap. I think there is more room on the sides since the pi is in the middle.
                And could you please give me the pinout you used to connect the screen to the pi ? I have 8 pins, labelled LED, SCK, SDA, AO, RESET, CS, GND and VCC. The @moosepr 's signature's guide uses different pinout, and I have to admit that I understand absolutely NOTHING in electronics (so I'm proud to have reach this far without help ^^'). Thanks !
                • ArvesterA
                  Arvester
                  For the fun:
                    obsidianspider @moosepr
                    @Arvester I haven't attempted to wire one up after removing it from the board yet, but this is what @moosepr gave me as far as how to wire it up on the board. Tracing things through to figure out which pin on the screen matches up to the pins on the PCB shouldn't be too big of a deal. That will be my next step. Once I get that working I'll be sure to post up what I came up with.
                    @moosepr said in Pi in a Dreamcast VMU Build - WIP:
                    @obsidianspider lets see if i can fill in the blanks for you
                    1 - 3.3v
                    2 - gnd
                    3 - gpio 8 (pin 24)
                    4 - gpio 25 (pin 22)
                    5 - gpio 24 (pin 18)
                    6 - gpio 10 (pin 19)
                    7 - gpio 11 (pin 23)
                    8 - 3.3v (can be the same as pin 1)
                    my schematic is a little messy, lots of crossovers. tis something i need to refine
                    • mooseprM
                      moosepr
                      here you go, a more fleshed out version
                      VCC - 3.3v
                      GND - gnd
                      CS - gpio 8 (pin 24)
                      RESET - gpio 25 (pin 22)
                      AO - gpio 24 (pin 18)
                      SDA - gpio 10 (pin 19)
                      SCK - gpio 11 (pin 23)
                      LED - 3.3v (can be the same as pin 1)
                        The big brown truck dropped off a little silver battery today. It looks like it's going to fit perfectly.
                        cellyC 1 Reply Last reply Reply Quote 1
                        • cellyC
                          celly @obsidianspider
                          @obsidianspider awesome! Now get back to work!!
                          Currently Playing: Tetris (Gameboy)
                            After about four hours I managed to make some good progress in the garage today.
                            • I removed the 1.44" TFT from the PCB, traced things out (the v2.1 screen has 13 pins, but the v1.1 screen only had 12), wired it up, and got it working.
                            • I also hooked up one of the self-contained surface mount piezos and while it's not loud, it's pretty nice, and definitely better than silence.
                            • I tested things out while connected to an actual Pi Zero instead of the Pi 2 that I'd been using for most of my testing. I remember now how slow those things are, but for what this toy will be, a novelty, it's totally fine.
                            I made a brief test video so you can get an idea of the sound quality of the piezo. This is with the mixer set to 100%.
                            I still haven't tested with the buttons and the screen and the piezo all at once on my test Pi Zero, but I'm not too worried about that. I also haven't tested running things directly from a LiPo, but @moosepr has proven multiple times that that's not an issue, so instead of reworking my test rig to try to prove out those things I'm going to move on to trying to fit things into the case as nicely as possible. Luckily I have two of those blue VMUs to test with before I do it "for real" with one of the off-white VMUs that @celly gave me.
                              Ah! Someone on YouTube already finished one!
                              The screen fits really well, and the audio is really nice too. I wonder what the inside looks like...
                                It's uncomfortably tight, but I managed to fit all the components inside, without wires.
                                I want to do some more fiddling with things, but after 7 hours of working on this today, I'm a bit fried. I don't want to go breaking something.
                                cellyC 1 Reply Last reply Reply Quote 2
                                • cellyC
                                  @obsidianspider yours will be fine. The test fit looks good to me. 👍
                                    With things being a bit too snug with the IDE cabling I was using for button connections I went another route and tried using some magnet wire. It took all day, but I think I have it. Today I'll be trying to connect everything up to a test Pi to ensure functionality (including the battery, switch, charging board) before I smoosh it back into a case.
                                      Today I managed to test all of the components outside the case, and everything works with my test Pi. Running off the battery without a booster works just fine with a Zero.
                                      Cranking up the volume in RetroArch makes the piezo loud enough to hear for general gaming, even if it's not quite high fidelity.
                                      Everything plays really nicely now that I'm using the board where I soldered to the chip pads instead of the old "make your own test pad" method.
                                      Next up I need to make everything fit in the actual case. First up, removing unnecessary stuff from a Pi Zero. This looks awful, but it works. If anyone has tips on removing the USB ports, HDMI port, or camera connector in a cleaner manner, please let me know.
                                      Every little bit of thinness is going to help with this build.
