    Xin Mo Controller Issue
    xinmocontroller
    5 Posts 3 Posters 1.5k Views
    • I
      IWANIAK
      Hey guys,
      I'm currently pulling my hair out as nothing seems to be working when trying to setup the player 2 Joystick on my Arcade machine. I have followed a bunch of different tutorials online, with non of them solving my issue. I am currently using the latest version of Retropie and have never done this before so forgive me if im missing something.
      Here is the tutorial I have been following:
      http://blog.petrockblock.com/forums/topic/how-to-get-xin-mo-dual-arcade-working-with-retropie-easy-guide/
      Any advice would be much appreciated!
      Kind regards,![0_1490624806235_IMG_7689.jpg](Uploading 100%)
      S
      • ShakzS
        Shakz
        If player 2 is not showing up you can try this....
        If you trust me....I don't know why you would but you can just run the commands below on your pi.
        wget http://eazyhax.com/pitime/cmdline.txt.xin
        sudo cp /boot/cmdline.txt /boot/cmdline.txt.bkup
        sudo cp cmdline.txt.xin /boot/cmdline.txt
        If that does not work you can rollback the changes with the following lines.
        sudo cp /boot/cmdline.txt.bkup /boot/cmdline.txt
        You will need to reboot for the changes to work.
        sudo reboot
        Hope this helps your sort it!
        RetroPie tips, tricks, and tweaks: https://www.youtube.com/eazyhax
        • I
          IWANIAK
          Cheers buddy that has sorted it :) Really appreciate it.
          • ShakzS
            Shakz
            You bet man. Glad I could help :-)
              graf
              I have done the exact same thing. retro pi picks up the two gamepad (which is cool). I configure p1 and then OK. when I play a FBA game player 1 is all perfect with the controller. Then I go back and configure gamepad 2. I set it all up .
              Then I goto FBA and P1 is all cotrols are in the oppoiste direction. And all the buttons are wrong (for SF2 Hard punch and hard kick are gone). But P2 is all perfect.
              So I goto retroarch and i check P1 and P2 . P1 has been configured for Xin Mo #1 and P2 has been configured for Xin Mo #2.
              However in mame-advance everything is all perfect.
              Any idea
