    Carousel theming help (left align)
    carousel mod
    31 Posts 8 Posters 10.3k Views
      robertybob
      Hi guys,
      I'm trying to stick the carousel to the left of the screen, but I can't for the life of me figure out how to do it. Either it goes to the right or dead centre (as below)
      This is the code I'm currently using. Can anyone help? :)
      <carousel name="systemcarousel">
        <type>vertical</type>
        <pos>0.020 0.039</pos>
        <size>1 0.8000</size>
        <color>FFFFFF00</color>
        <logoScale>1.5</logoScale>
        <logoSize>0.125 0.155</logoSize>
        <maxLogoCount>4</maxLogoCount>
      </carousel>
      AlexMurphyA S mattrixkM 4 Replies Last reply Reply Quote 0
      • AlexMurphyA
        AlexMurphy Banned @robertybob
        @robertybob Have you tried a negative number for the X position?
          robertybob @AlexMurphy
          @AlexMurphy Nope! I'm an idiot, thanks for your help! :D
            Syhles @robertybob
            Did you try setting <origin> ?
            R AlexMurphyA 2 Replies Last reply Reply Quote 0
              robertybob @Syhles
              @Syhles I'm not actually sure what Origin does, I'm doing most of this by trial and error (and I still haven't completely learnt what everything does lol)
              • AlexMurphyA
                AlexMurphy Banned @Syhles
                @Syhles Yeah, this could work too. Set the origin point and position relative to that. I assume the default origin X point is 0.5.
                  Syhles @robertybob
                  @robertybob
                  Let's you choose where it defaults to before editing <pos>
                    Syhles
                    0 0.38375 is Default <pos> for the carousel.
                    https://github.com/jrassa/EmulationStation/blob/master/THEMES.md#carousel
                    • AlexMurphyA
                      @Syhles Odd. Perhaps I mean the system logos, which is what he is trying to change here.
                        Syhles @AlexMurphy
                        @AlexMurphy
                        The code he posted is for the carousel, if he wants to move the logos on the system select screen he has to edit that.
                          Syhles @robertybob
                          @robertybob
                          My carousel is currently vertical and on the left side of the screen
                          Heres my code try it if you want
                          	<carousel name = "systemcarousel">
                          		<pos>0.027   0.05</pos>
                          		<size>0.33 0.835</size>
                          		<color>00000000</color>
                          		<logoSize>0.20 0.15</logoSize>
                          		<maxLogoCount>5</maxLogoCount>
                          	</carousel>
                          R L 2 Replies Last reply Reply Quote 0
                            robertybob @Syhles
                            @Syhles @AlexMurphy Thanks guys, you both fixed my issues :)
                            • mattrixkM
                              mattrixk @robertybob
                              @robertybob Your original problem was the <size>. You had the X-size set to 1, which is 100%, and the carousel is in the middle of that.
                              S R 2 Replies Last reply Reply Quote 3
                                Syhles @mattrixk
                                @mattrixk
                                I did not know that. I've just started messing with the carousel.
                                • mattrixkM
                                  mattrixk @Syhles
                                  @Syhles For the Carousel the <size> property works the same as any <image> element.
                                  • <size>1 1</size> sets the element to be 100% wide and 100% high
                                  • <size>0.75 0.5</size> sets the element to be 75% wide and 50% high
                                  The logos in the Carousel sit in the middle of the element, so if you have a <size>1 x</size> then the logos will be in the middle of the screen, now matter what (unless you change the <pos>).
                                  S 1 Reply Last reply Reply Quote 3
                                    Syhles @mattrixk
                                    @mattrixk
                                    Thanks that's very useful to know.
                                    • mattrixkM
                                      mattrixk @Syhles
                                      @Syhles No worries, glad to help.
                                        robertybob @mattrixk
                                        @mattrixk said in Carousel theming help (left align):
                                        Oops!
                                        Last night I had changed it to:
                                          <pos>-0.350 0.039</pos>
                                          <logoScale>2</logoScale>
                                          <maxLogoCount>3</maxLogoCount>
                                        Which gave me this:
                                        Do you think I am ok to leave it as it is?
                                          Syhles @robertybob
                                          @robertybob
                                          Are you happy with how it looks? If yes then leave as is, lol.
                                          I just spent 2hrs arguing with the Modern theme to get Carousel and System screen just right and now I'm afraid to touch anything or it will burst into flames.
                                            **Scannigan**
                                            Just stumble across this post and was hoping someone could talk me through implementing the "carousel" element.
                                            I've already attempted to modify my existing theme xml, however that broke my theme, I even tried using the "supported feature" and that didn't work either.
                                            I'm using Retropie 4.2 and according to GUI looks like I'm using ES V2.1.4RP
