    Problem with Xin-Mo dual player + 3rd/4th player USB gamepad
    inputxin mo dualusb gamepad4 players
    3 Posts 2 Posters 1.2k Views
      acidchris
      Hello,
      Hopefully one of you guys can help me out on this, because i'm running out of ideas.
      I'm having a Xin-Mo 2 player setup on Raspberry Pi3 using latest RetroPie software.
      I recently bought 2 Buffalo USB SNES gamepads and configured them also through EmulationStation.
      I'm having troubles getting player 3 + 4 (gamepads) to work with RetroArch emulators (Megadrive Bomberman to be exact).
      • maximum players set to 4
      • input binds checked for all 4 controllers
      What it does...as soon as i connect the USB gamepads, the Xin-Mo behaves as 1 Player only. So in the game it controls player 1 and 2 at the same time. The USB gamepad is not working at all, even though everything looks good in the retroarch menu.
      As a sidenote, if i unplug the Xin-Mo and just use the USB gamepads configured for player 1 and 2 it works like a charm. I just cant get more than 2 players to work.
      Does anyone have an idea whats wrong?
      Any help appreciated,
      best regards
        edmaul69 @acidchris
        @acidchris are you going into retroarch gui and changing the controller to the multitap?
          acidchris @edmaul69
          @edmaul69 hi. yes all changes were made within the RetroArch GUI. I checked QuickMenu -> Controls and from Settings -> Input. Both looked ok.
