    Need a little help here (Pi 0 Boot Issues)
    raspberry pi 1
    5 Posts 3 Posters 985 Views
      Brooklynbred1981
      Having some issues getting my Raspberry pi zero 1v. 3 to boot... Not sure what I'm doing wrong... I'm not even sure that the retro pie that I downloaded and put on the micro SD card is even on there... I have a few questions if anyone can help me or point me in the right direction
      • AlexMurphyA
        AlexMurphy Banned @Brooklynbred1981
        @Brooklynbred1981 Tell us what you are doing and hopefully we can tell you what you are doing wrong. You need to give more info than "help, it's not working!". Also, why did you post in this section? Surely your question should have been in "Help & Support".
          Brooklynbred1981 @AlexMurphy
          @AlexMurphy sure thing.... So first of I formatted the SD card and tried to run win32 disk imager kept seeing notepad pop up.... I proceeded to download retro pie artwork. After that I tried to put everything onto the formatted sd card as the directions instructed. I proceeded to test the device and that's as far as I've gotten. Nothing lights up.. Retro pie doesn't boot to the load screen.
            BuZz administrators @Brooklynbred1981
            @Brooklynbred1981 topic moved.
            You need to provide more detail. Read the link at the top of the page as you agreed when registering.
              Brooklynbred1981 @BuZz
              @BuZz OK sure thing best of my knowledge I'll supply more details
              Running windows 7
              Downloaded retropie from Raspberrypi.org
              Used the Jessie download link
              Used a SD formatter I downloaded
              Just trying to load some ROMs onto this thing
              I have the Raspberry pi zero 1v 3 (can't see the act led)
              16gb SD card with adapter
              Power source I'm running off a adsoter
              From my cell phone (meets minimum requirements)
              You think that maybe the Raspberry could be faulty? (had a big blue stripe drawn on the logo on top) could be a bad refurbished one...
