    Console Boxes Theme (WIP)
    themenes
    73 Posts 12 Posters 25.7k Views
      SuperSirLink
      Been working on a theme to mimic boxes of the consoles. I started with the NES, still working on a few issues. Genre text collides with the description when it is too long.
      The goal is to get screenshots in that CRT image...
      Edit: Link to download on GitHub
      NYIslanders91N 1 Reply Last reply Reply Quote 17
      • NYIslanders91N
        NYIslanders91 @SuperSirLink
        @SuperSirLink I really like it.. Look Forward to it.
          duiz
          This looks amazing, exactly what I been looking for!
            SuperSirLink
            Thanks! Still reading up on the new video feature and seeing if that can be used to populate the screenshot... Not sure yet how to pull that off...
            But here is another shot (manually replacing the static):
            mattrixkM 1 Reply Last reply Reply Quote 1
              A Former User
              Looking good!
              • RookervikR
                Rookervik Global Moderator
                Looks a lot like Romshelf.
                • mattrixkM
                  mattrixk @SuperSirLink
                  @SuperSirLink looks good.
                  If you need help with videos and such you can take a look at the ES Toolkit. It has a version of the Carbon theme that supports video, and also a custom theme called BaseVid that supports both video previews and the new Carousel mod that lets you style the System View.
                  The Toolkit also contains scraped media (logos, screenshots, box art, videos, mix images, etc) for 100 games over 5 systems.
                    SuperSirLink @mattrixk
                    @mattrixk Thanks! I did pull down version 1.1 of the kit, but I am another Mac user, so didn't use the portable EmulationStation... Might have to setup a VM to try it... Didn't see where I could access the files that make up those themes. Are they loose in the structure like you have the fake roms?
                    Also used you guide on the wiki, that was really helpful! Do you plan to update the guide and cover some of this new structure?
                      johnny_salonica
                      This theme made me register to the community and congratulate you @SuperSirLink !
                      I really love all the themes but this is absolutely stunning! I really wish you can continue and complete more and more consoles! The NES theme could be even be part of the NES classic mini.
                        SuperSirLink @johnny_salonica
                        @johnny_salonica Thank you! I did all the graphics myself in Photoshop, except the screenshot, box art, and Nintendo logos... The quality seal needed some work as getting a good one that matched the wording used on the NES box was a bit of a challenge... Need to design some stars yet, those are the stock ES ones...
                        • OmnijaO
                          Omnija
                          This post is deleted!
                          • mattrixkM
                            @SuperSirLink: You can find the BaseVid and Carbon theme in the Themes folder of the Toolkit.
                            I'm at the beginning of some time off, so I'll hopefully have a chance in the coming week to update the guide on the wiki (If I don't just spend it all lying on the couch and catching up on games).
                              bobbycopter
                              I would switch over to your theme in a heartbeat if it was already completed. I really like how you managed the available space. Boxart + Screenshot + description while keeping the list simple and clear. I'm also fond of your idea using the CRT for screenshots and not videos. Videos are great for showing off, but unfortunately I had to realize it's just too 'noisy' and 'hectic' for me.
                              The nostalgic feel of your theme is through the roof, looking forward to see the other consoles.
                                johnny_salonica @SuperSirLink
                                @SuperSirLink I hope you can keep up and keep the "same" looking-feeling for the rest of the consoles too. I can even help you with photoshop or other minor graphical things if you want to.
                                  SuperSirLink @bobbycopter
                                  @bobbycopter said in Console Boxes Theme (WIP):
                                  I got a complete in box 1990 era action set and while looking at the box with the screenshots, thought it would make a great theme... That was my inspiration... I think the videos are more at place for those TV/gameroom themes a few are working on... But videos don't really capture what I was going for... But if I can use the code that makes videos possible to fill in the screenshots, I will...
                                  @johnny_salonica said in Console Boxes Theme (WIP):
                                  I am going to do boxes for the systems I play which are ones I had as a kid... Atari2600 will probably be next once I work out the last of the details on the NES box... The Atari box also used the really exaggerated CRT frame to place the screenshots in. Not sure if this format would be true to every system. If there is interest, I will likely open it up to some help if others want to do the other systems... I don't have a lot of time to work on stuff like this and it would help bring it to completion faster...
                                    SuperSirLink
                                    So the immediate need, is figuring out how to get the meta data fields to truncate like the game list does if there is not enough space. Anyone know how to best accomplish that? Didn't see any values listed on the themes readme that would allow that to happen... Guess we could always do some manual clean up and trim those down (wasn't that many on my list), but would be nice to have a "failsafe"...
                                      duiz
                                      Any update on this theme and when we can get to play around with it?
                                        SuperSirLink @duiz
                                        @duiz said in Console Boxes Theme (WIP):
                                        Still working on it... I am still playing around with these new features to get the screenshots populated... Think I am also going to take advantage of the carousel mod now too... That big grey bar was really killing the feel of the box front effect... :)
                                          SuperSirLink
                                          So I am beating my head on the desk wondering my my changes were not working. Out of desperation I copy over the basevid theme from the toolkit and to my surprise the new features didn't work! LOL okay, now I don't feel so bad...
                                          I have been doing my theme testing on a Pi1 using the latest RetroPie image 4.2... The new carousel mod features not in the 4.2 image?
                                          • herb_fargusH
                                            herb_fargus administrators @SuperSirLink
                                            @SuperSirLink it's not.
