    Dreamcast dc_flash.bin 74e3f69c2bb92bc1fc5d9a53dcf6ffe2 #help
    dreamcasthelpchecksumdcflashdcflash.bin
    4 Posts 4 Posters 5.8k Views
      antsmalls12345
      Hello, new to RetroPie, I've able to get my hands on different bios for Dreamcast but can't get it to play. I've done the renaming the file to "dc_flash.bin" multiple times.
      I recently found out about the MD5 checksum, and it has to be 74e3f69c2bb92bc1fc5d9a53dcf6ffe2, which i have not been able to locate.
      Can we change the checksum value?
      Is there something I'm doing wrong?
      #dreamcast #help
      • AlexMurphyA
        AlexMurphy Banned @antsmalls12345
        @antsmalls12345 The checksum is calculated based on the contents of the file. If the BIOS you have has a different checksum then that means the contents are different from the required file. It's not a matter of changing the checksum, it's a matter of obtaining a file that generates the correct checksum.
        Dreamcast on wiki
          archangel175
          This post is deleted!
          jonnykeshJ 1 Reply Last reply Reply Quote -1
          • jonnykeshJ
            jonnykesh @archangel175
