    Help Getting Dreamcast to work
    raspberry pi 3bdreamcastnot running
    4 Posts 2 Posters 1.4k Views
    • FlashyThingF
      FlashyThing
      Hi guys. So I'm having a lot of trouble and I don't know why. I downloaded the Dreamcast bios and put the files in my BIOS folder. I then put a game, specifically Shenmue, in the Dreamcast ROMS folder and it shows, but just stops when I try to run it. I should also mention that I have a Raspberry Pi 3 model B, and am running the latest (4.2) version of Retropie.
        BuZz administrators @FlashyThing
        @FlashyThing maybe the bios is wrong or named incorrectly or the cd image is bad. Need more information.
        FlashyThingF 1 Reply Last reply Reply Quote 0
        • FlashyThingF
          FlashyThing @BuZz
          @BuZz I did check that. I also checked Google for days and I can't seem to get this thing to work.
          BuZzB 1 Reply Last reply Reply Quote -1
            @FlashyThing You can't have done, since you have not provided much of the requested information. I have no idea about filenames, or anything you are referring to. What Bios ? What game ?
