    Storing Kodi movies on separate USB drive than roms mount?
    kodiautomatic mountusb driveexternal hdd
    3 Posts 2 Posters 2.6k Views
    • E
      ezeitgeist
      Pi Model: Pi 3
      Power Supply used: (If using a Pi): 5V power supply purchased with Pi 3
      RetroPie Version Used: 4.1
      USB Devices connected: USB flash drive (64gb storing roms) ... WANT TO ADD a powered USB Drive for Kodi files.
      Error messages received: None yet, haven't tried anything to mess it up, yet.
      I am using the automatic mount method (https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive#automatic-mount-easiest-method) for my ROMS. I am new to Kodi and have been legally ripping my dvds to watch. Can I store those files on a second USB drive plugged into the rPi?
      Do I just add a "retropie-mount" folder and then the proper movie structure folders below that to that new drive as well or will that mess everything up and not work?
      Looking for the simplest way to store and watch my files.
      • DigitalMonkeyD
        DigitalMonkey Banned
        Just put the videos files on the second drive. Dont have to do anything special.
        I didnt anyway.
        • E
          ezeitgeist @DigitalMonkey
          @DigitalMonkey Oh, that is sweet! Thanks. Sorry, I thought it would just be more complicated!
