    Problems with joysticks and diagonals....
    9 Posts 3 Posters 3.6k Views
      alexpagp
      Hi all;
      i have bought two joysticks that are connected to a usb board and after mapping the bottons and joystick the diagonals don't work , concretely the NE diagonal doesn't work correctly and i don't know why...
      Some people told me that i could be a drivers problems or some stuff like that .
      Any suggestions???
      Thank you in advance
      FinheadF 1 Reply Last reply Reply Quote 0
      • FinheadF
        Finhead @alexpagp
        @alexpagp said in Problems with joysticks and diagonals....:
        Hi all;
        Any suggestions???
        Are you sure they are 8 way? They could be 4 way sticks.
          alexpagp
          well, the joysticks have 4 conections and all work fine . Up, down;left and right work perfectly.
          Or what do you mean with the 8 ways??
          thank you.
          • FinheadF
            Finhead @alexpagp
            thank you.
            There are 4 way and 8 way joysticks.
            Maybe list the brand and model number or even a link to the joystick you have.
              alexpagp
              its only in one diagonal. So its for sure a joystick with 8 ways.
              thank you
              glennlakeG 1 Reply Last reply Reply Quote 0
              • glennlakeG
                glennlake @alexpagp
                @alexpagp Is you joystick one of the old Happ Controls compitition joystick with the open bottom and 4 cherry switches? If it is you may have something loose that isn't hitting both switches at the same time. We liked the old Happ joysticks because you could put a spacer between the switch and the actuator so you wouldn't need much of a movement to hit the switches.
                  alexpagp @glennlake
                  @glennlake Hi! My joystick the model I show you in the picture .
                  http://www.olimex.cl/en_US/website/image/product.template/10284_8f37bfd/image/900x900
                  • glennlakeG
                    glennlake @alexpagp
                    @alexpagp I missed you saying you have 2 joysticks. Are they both giving you the same trouble? I have never used one of these but a little googling tells me there is a restrictor plate on the bottom that can change it to 2 way, 4 way or 8 way action. Could that be causing some of the trouble? Are they both doing the same thing? One thing you could try is to move the connections swapping north-south and east-west and see if the problem moves.
                      alexpagp @glennlake
                      @glennlake , sure, I will try to do what you say.
                      Let's see what happen!
