    Project help needed
    gamingstationprojectraspberrypiretro
    37 Posts 7 Posters 10.1k Views
    • L
      Luxous @TMNTturtlguy
      @TMNTturtlguy Thanks for the info, I need the set up to have two player options, with dual controls.
      do I just buy two sets of buttons etc
      • TMNTturtlguyT
        TMNTturtlguy @Luxous
        @Luxous I don't know what you mean by 2 player options with dual controls? Are you trying to have a 2 full payer setup (1 joystick and 4 t0 8 buttons per player)? Or are you saying you want to have 2 full sets of controls for each player (meaning 2 joysticks or each player, a total of 8 joysticks?)
        If you are just trying to create a standard 2 player setup, you can purchase the easyget usb arcade controls from several places including ebay, amazon if available where you are at, and several other online re-sellers. They sell them in 2 packs, meaning you get 2 full player setups, so you buy 1 set and it gives you 2 joysticks, 2 usb encoders and 2 full sets of buttons.
        • L
          @TMNTturtlguy I just meant I wanted 2 full player set ups, so each station 2 people can play at same time.
          so far ive bought 7 of these set ups, 7 raspberry pi 3 units, memory cards, power packs and 7 monitors
          do I need power blocks also?
          • TMNTturtlguyT
            @Luxous You do not need power blocks, they are an add on. I do not use power blocks as i mentioned above in my earlier post. Power blocks can do a lot of cool things, however I choose to go with the USB arcade controls for ease of use and ease of multiplayer capabilities.
            The main thing you need to consider is how you are going to power up and power down each pi unit. I use a toggle switch like the original arcade cabinet I rebuilt used. I wired the toggle to a surge protector. The surge protector powers my pi, my powered usb hub from PiHut, the lights on the arcade machine, my speakers and my monitor. When i switch the toggle on, everything is powered up at the same time. When i shutdown, I properly shutdown the pi through the menu, shutdown system. I wait about a minute and then i simply flip the toggle off, and the entire arcade machine is powered down.
            Sorry for the long answer. No you don't need a power block. You just need to decide if you are going to use USB controllers with LED lights, you need to have a Powerd USB hub. You also need to figure out how to properly startup and shutdown your units.
            • L
              @TMNTturtlguy perfect, thanks. the controller set ups are all joysticks and buttons that will presumable be controlled via the usb block etc that comes with them, im sure they are led too so does that mean the hub will control all of that?
              I was hoping that there would be a more simple way of startup and shutdown? ie a button possibly?
              • TMNTturtlguyT
                @Luxous said in Project help needed:
                Yes, the Powered USB up from PiHut will power the buttons and joystick as well as the LED lights for the buttons. You will need this so that the buttons/LED lights do not draw power from the raspberry pi itself.
                If you want to do something like this, you will need to look into the PowerBlock. I have not used one, so I cannot speak to it. PowerBlock Link
                • L
                  Luxous
                  So.....
                  yesterday all 7 stations arrived, ive installed retropie on them all and also various consoles and games, custom splash screen etc etc
                  my problem is that ive bought arcade joysticks and buttons, pair share the same "dual usb encoder" both joysticks and all buttons connect to this encoder then i plug in the usb. ive tried numerous times to have emulation station listen to controls yet when i start a game, most buttons dont work, when i hit start for exmple some characters jump - its driving me insane :)
                  any help much appreciated
                  CapemanC pjftP 2 Replies Last reply Reply Quote 0
                  • CapemanC
                    Capeman @Luxous
                    @Luxous What kind of encoder? Can you post a link to the brand and model?
                      pjft @Luxous
                      @Luxous Just to confirm, did you remap the controllers in EmulationStation, and are you using the libretro (lr- prefix) emulators?
                      • L
                        Luxous @Capeman
                        @Capeman thanks https://www.amazon.co.uk/gp/product/B06XFSTZLK/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                        • L
                          Luxous @pjft
                          @pjft i reset controls, as i had assumed i had messed up, ssh in and ran script to wipe controls, ran emulation station, one set of controls work, the second set have no effect at all
                          with regards to the libretro (lr- prefix) emulators, im unsure how to do that?
                            thedeathstar
                            For your controllers:
                            First thing I'd do is start up your pi with only the non-working controller plugged in and see if it recognizes it as a new controller that you need to configure.
                            Second, there's a test you can do to see what controllers are plugged in, and see what button presses correspond to numeric inputs on the pi. I'm guessing this video is still applicable:
                            If the two controllers give different inputs you might need to rewire your buttons. If certain buttons or the controller aren't recognized I would suggest going over your wiring with a fine tooth comb to make sure you didn't miss anything.
                            For the power on/off:
                            One option other than the powerblock is shown here:
                            I haven't tried it, so maybe someone else would be able to tell you if that's as robust of a solution as the more expensive hardware. At least you can test that with one of your extra buttons, and not have to worry about spending more money for now.
                            Another option would be something like this: https://mausberry-circuits.myshopify.com/products/shutdown-circuit-use-your-own-switch
                            The benefit (in my mind at least) is that I think it fully cuts power to the pi, but it requires an on/off switch.
                            • L
                              Luxous @thedeathstar
                              @thedeathstar thanks for the info, the arcade set ive got is two complete sets of buttons and joysticks but they share the same double encoder, so there is only one usb into the pi, this is why i think its only finding it as a single controller
                              • L
                                Luxous
                                SO ....
                                today i took one of the encoders off of the other button sets and connected the two separate sets of joysticks and buttons via two encoders, the pi then seen i had two sets of controllers.
                                i wipe the controllers settings and i go through emulation station programming joystick 1, everythings fine.
                                once in emulation station i then hit menu, configure joystick 2, everything seems to be working, only its not... it then throws off all controls for joystick one. only the bottons though not the joystick
                                • CapemanC
                                  Capeman
                                  I recommend you switch out to using a keyboard based encoder like the iPac 2. Those cheapo chinese encoders that come in those bundle kits are usually pretty low quality, and with no documentation there's no way to easily troubleshoot them. The iPac is more expensive, but infinitely easier to work with since it's recognized as a keyboard and not multiple gamepads.
                                    thedeathstar @Luxous
                                    @Luxous A possibility is that you could find the input numbers for the buttons for each users controls (using both controls in one usb controller still) and then set up the controller config file for each system using those inputs. Those config files are set here: /opt/retropie/configs/whatever system you are setting up for/retroarch.cfg
                                    The code you would change would be something like:
                                    player2_a = 1
                                    player2_b = 2, etc.
                                    You would leave the player 1 controls, and just change the player 2 controls. This may not even work though because it may require player2 to be a separate controller.
                                    On the other hand, you could do a similar thing using two of your current controllers for each system. The controllers may not be consistent with each other , but you could get the input number for each one and set the player two controls to those inputs.
                                      thedeathstar
                                      if the second way works, you could get away with not having to buy new control boards for all of your systems.
