    How to get Intellivision to work on 4.1
    intellivisionretropie 4.14.1
    34 Posts 5 Posters 12.2k Views
    • ThatGuy-UNoT
      ThatGuy-UNo
      Hello RetroPie community,
      I need some help in getting Intellivision to run on RetroPie 4.1. I have looked at these videos on Youtube
      , [Removed: 2nd Video Links to ROM Sites] . I know the the second video is for OpenEmu but the concept is the same. I have download from different websites the required Bios files and still come into a roadblock. Can anyone lead me in the right direction? This is my last conquer of gaming systems I want for my RetroPie :P
      mediamogulM edmaul69E 2 Replies Last reply Reply Quote 0
        mediamogul Global Moderator @ThatGuy-UNo
        @ThatGuy-UNo
        Have you read and followed the RetroPie documentation? It could be that you're testing games that require memory map files as noted here.
        ThatGuy-UNoT 1 Reply Last reply Reply Quote 0
        • ThatGuy-UNoT
          ThatGuy-UNo @mediamogul
          @mediamogul Thanks, I totally misread that. I will let you know if it works!
            edmaul69 @ThatGuy-UNo
            @ThatGuy-UNo you need to give the bios file 775 permissions. They used to go in /opt/retropie/emulators/jzintv/roms/ but i think the retropie 4.2 version of jzintv changed it to /home/pi/RetroPie/BIOS/ so i would try putting them in both locations.
              @edmaul69
              It looks like the new location is noted in the docs. The video he used might have pointed to the older location.
                edmaul69 @mediamogul
                @mediamogul i had to change it back because i have to change jzintv to my copy everytime i update because retropie uses a really old version that a few games like the homebrew ms pac-man wont play on. There was a problem in jzintv that didnt correctly emulate something that a real intellivision did.
                  @edmaul69
                  Are you now using the most recent jzintv? If so, how does it run?
                    @mediamogul the version i use, i have had for a long time. The one i use is available on intellivision.us . Not sure of anything that the version that retropie might have changed, but i know that it doesnt play ms. pacman so i dont try anything further.
                    • ThatGuy-UNoT
                      ThatGuy-UNo
                      @mediamogul Hello again. So I got the bios from the video that I posted. I download the game Space Armada and renamed it on the spreadsheet in addition to downloading the right config file and renaming it as well. Here is a picture!!![0_1493675936754_Intellivison.JPG](Uploading 100%) What am I doing wrong?
                      • ThatGuy-UNoT
                        ThatGuy-UNo
                          @ThatGuy-UNo
                          It doesn't look like I needed a config file for 'Space Armada'. Can you post it's contents?
                          AlexMurphyA ThatGuy-UNoT 2 Replies Last reply Reply Quote 0
                          • AlexMurphyA
                            AlexMurphy Banned @mediamogul
                            @mediamogul Feck the Intellivision. ColecoVision is where it's at. Better games, better graphics. Check it out.
                            • ThatGuy-UNoT
                              @mediamogul What contents do you mean? I can't simply send a link where I got the game cause that be breaking the forum rules. What games can I download that will work using the bios files that I got from the 2nd video?
                              @AlexMurphy Appreciate your enthusiasm on the other side of the fence
                              AlexMurphyA mediamogulM 2 Replies Last reply Reply Quote 0
                              • AlexMurphyA
                                AlexMurphy Banned @ThatGuy-UNo
                                @ThatGuy-UNo What fence? ColecoVision is better!!!! We can have both. That's why I love emulators. I'm only trying to have a joke.
                                  @ThatGuy-UNo
                                  I was referring to the contents of the config file.
                                  Try something basic like 'Burger Time!' and see if it loads. It shouldn't need a memory map. If it doesn't work, we'll compare the checksum of our BIOS files.
                                  @AlexMurphy
                                  pft... Everyone knows all the best titles came out of GameaVision.
                                  • AlexMurphyA
                                    @mediamogul Nonsense! All the best games were on the FUNARAMA-VIDEO-FUN-SUPER-MACHINE I had them all. And I beat all 756 of the games released. Even the really shitty ones involving Smurfs!
                                    • ThatGuy-UNoT
                                      ThatGuy-UNo @AlexMurphy
                                      @AlexMurphy Lol sorry :P just being frustrated with the emulator atm :/
                                      • AlexMurphyA
                                        @ThatGuy-UNo You own a Pi. Frustration is a thing. I remember when I was about to stamp on it like a horrible cockroach. I was where you were once. Don't lose hope!
                                        • ThatGuy-UNoT
                                          @mediamogul The contents of the config file where the google doc ones from the wiki
                                            @ThatGuy-UNo
                                            I'm re-familiarizing myself with the mappers and if memory serves, mapper 0 loads by default unless otherwise instructed and therefore any game using it doesn't need a config file. That leaves only 30 to be made from a North American set.
