Xboxdrv or XINIT problem
Hi,
I'm on PiBoy XRS with Pi4 and Retropie 4.8.6.
I have installed some ports and configured successfuly xboxdrv mapping. Now I'm trying to run native Unreal Tournament 99 with box89, xboxdrv, and xinit.
My problem is controls are not working the first time game is launched. When I kill game process in ssh terminal and restart game in EmulationSation, all working perfectly.
I tried to find solution since two days without success. I don't find the difference between first broken launch and the nexts. Seems like input conflict between xinit and xboxdvr the first time or missing initialisation.
When I remove the necessary xinit command for display, sound and controls are working all the time.
With xinit and without xboxdrv, connected keyboard/mouse working but not PiBoy controls.
With xinit and xboxdrv, keyboard/mouse and PiBoy not working at the first launch, but all works perfectly after killing process and restart game.
Here is my two scripts for launch the game and the xboxdrv cfg :
#!/usr/bin/bash sudo killall xboxdrv sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \ --silent \ --detach-kernel-driver \ --config /home/pi/RetroPie/roms/ports/PiboyXRS_unreal_xboxdrv.cfg \ --ui-axismap X1=KEY_Q:KEY_D,Y1=KEY_S:KEY_Z \ --deadzone 5000 \ & sudo xinit /home/pi/RetroPie/roms/ports/UnrealTournament.sh sudo killall xboxdrv
#!/usr/bin/bash cd /home/pi/RetroPie/roms/ports/ut99/System box86 ut-bin-x86
[xboxdrv] evdev=/dev/input/event0 dpad-as-button=true trigger-as-button=true [evdev-absmap] ABS_X=x1 ABS_Y=Y1 ABS_RX=x2 ABS_RY=y2 [ui-axismap] x2=REL_X:5 y2=REL_Y:-5 [evdev-keymap] BTN_SOUTH=b BTN_EAST=a BTN_NORTH=y BTN_WEST=x BTN_START=guide BTN_SELECT=start BTN_TRIGGER_HAPPY4=dd BTN_TRIGGER_HAPPY3=du BTN_TRIGGER_HAPPY1=dl BTN_TRIGGER_HAPPY2=dr BTN_TR=rb BTN_TL=lb BTN_TR2=rt BTN_TL2=lt BTN_THUMBL=tl BTN_THUMBR=tr [ui-buttonmap] du=KEY_UP dd=KEY_DOWN dl=KEY_LEFT dr=KEY_RIGHT rt=BTN_LEFT lt=BTN_RIGHT tr=KEY_T tl=KEY_R x=KEY_A b=KEY_SPACE y=KEY_1 a=KEY_ENTER lb=KEY_F1 rb=BTN_RIGHT guide=KEY_M start=KEY_ESC
