Please Help... Control Block not working properly.
So I just hooked up all my arcade controls to my control block and installed the driver. The thing is when I use jstest to test the inputs it says all of the buttons are on even though I'm not pressing anything. I cannot figure it out I could really use some pointers. Thanks!
Can you post a copy of our configuration file here?
If possible, an image of your hardware setup would also be good to try to analyse the problem. -
@petrockblog Thanks for the reply, but I actually figured it out today. I had the first revision of the Control Block board and I was trying to use the drivers for the second revision.
Glad to hear that you figured it out!
