    SupaCEC - A utility to switch TV inputs when a controller is connected
    cecpackagespackagehdmi cechdmi
    29 Posts 8 Posters 6.8k Views
      psyke83 Global Moderator
      OK, this definitely works! ;)
      ACTION=="add", SUBSYSTEM=="input", RUN+="/bin/bash -c 'echo as | /usr/bin/cec-client -s -d 1'"
      The problem was either the nested apostrophes or missing PATH. I don't want to annoy the person watching the tv, so you'll need to test, but the above line worked for me. I assume it executed the command three times, however, so refining is a good idea.
      This filter works for my DS3 controller causing it to execute once:
      ACTION=="add", SUBSYSTEM=="input", KERNEL=="js[0-9]*", RUN+="/bin/bash -c 'echo as | /usr/bin/cec-client -s -d 1'"
      • SanoS
        Sano
        Ok finally found a simple solution working here, if anybody could test :
        First install cec-utils :
        sudo apt-get install cec-utils
        Create a /etc/udev/rules.d/10-cec.rules with this line:
        ACTION=="add", KERNEL=="js0", SUBSYSTEM=="input", RUN+="/bin/bash -c '/bin/echo as | /usr/bin/cec-client -s -d 1'"
        Note the rule will match only for the first controller (js0) and execute only once, and also note the full path to binaries.
        Reload udev rules :
        sudo udevadm control --reload-rules
        When you plug the first controller, the tv should switch to retropie.
        I tested it with (wireless) PS3 controller and USB arcade stick.
        @psyke83
        I was so concentrated testing things that I missed your post. Congrats, you found it first :)
        The good thing is we both came to the same conclusions.
          superterran
          Awesome @Sano and @psyke83! I haven't had a chance to test this yet, but I like where this was headed and wanted to formalize something. I'll hopefully test it tonight, in the meantime if anyone wants to look it over https://github.com/superterran/SupaCEC/tree/refactoring-to-udev-rule
            psyke83 Global Moderator @superterran
            @superterran
            The script seems to work fine* - except for unnecessary sudo invocations - on my DS3 controller. The previous test only switched to the Pi when the tv was off, but yours will also switch HDMI inputs when the tv is on.
            • until you merge changes to the master branch, users need to specify the "refactoring-to-udev-rule" branch both in the curl instruction and manually appended to the gitPullOrClone line.
            Edit: hmm, the first test worked, but second test after waiting for controller to timeout didn't switch inputs.
              I've done further testing and come to the conclusion that cec-client only works reliably when a single command is invoked.
              Your script appears to send the two commands simultaneously per line - the "pause" & switch source command, but both of your rules match my DualShock 3, which means it's 4 commands being sent at once.
              The behaviour is unpredictable with your version; sometimes the tv will switch source and sometimes not. With my simpler version, it works more reliably, but it doesn't always work, especially after first boot. I have Kodi configured to start on boot, so it may be interfering somehow.
              • SanoS
                Sano
                @meleu :
                (Screaming like a movie character with fists toward the sky)
                Nooooooo ! Whyyyyyyy ?
                  meleu @Sano
                  @Sano yo! Whats up doc?! :-)
                  SanoS 1 Reply Last reply Reply Quote 0
                  • SanoS
                    Sano @meleu
                    @meleu It's my new (totally natural and not overacting) reaction to a downvote :)
                    I wish we had PM here...
                    Sorry !
                      meleu @Sano
                      @Sano OMG dude! Sorry! It was an accident (I was on the Android phone). You deserve an upvote!
                      I'm looking for a free time to join this conversation/development here. I'm interested!
                        Hello fellows.
                        I would like to say thanks! The cec-utils package is pretty handy. The udev rules are perfect!
                        The only addition I've made on my arcade build was adding a turn off monitor.sh script in RetroPie Menu.
                        #!/bin/bash
                        # turn off monitor.sh
                        # Actually puts the monitor on stand by mode.
                        echo standby 0 | cec-utils -s -d 1
