    NES controller not working with New ControlBlock2 build
    nescontrolblock2newbie question
    25 Posts 6 Posters 4.5k Views
      petrockblog Global Moderator
      Ok, I was able to reproduce your observation with NES controllers. I have fixed it a few minutes ago.
      There is now a dedicated NES gamepad type in the configuration: Use "nes" as gamepad type in /etc/controlblockconfig.cfg.
      • H
        Herzog Leto
        My problems are also gone. Thanks a lot!
        By the way, this time I used the Retropie-setup script to install the driver. Works fine.
          Sledrunner21
          Original poster here.
          I was able to install the latest driver using:
          wget -O - https://raw.githubusercontent.com/petrockblog/ControlBlockService2/master/install.sh | sudo bash
          I took me a while to understand the difference between US & UK keyboards to make the "|" (pipe) symbol. For those w/ US keyboards, use the lower right ALT + "~" (next to #1).
          I am struggling again w/ having and empty /ect/controlblockconfig.cfg file which is preventing me from setting the controller as NES or SNES.
          cd ControlBlockService2
          sudo nano /ect/controlblockconfig.cfg
          I can run jstest /dev/input/js0 and it shows driver 2.1.0 (same as before) and being set as arcade (I had switched it to SNES w/ the old driver back when I could open the config file).
          How do I get the /ect/controlblockconfig.cfg file to open again so I can edit it to NES now?
            You can restore the original configuration file by running the install script again, e.g., by running sudo ./install.sh from within the ControlBlockService2 directory.
              Also, the config file is located in the folder supplementary within the driver folder ControlBlockService2.
