    Rocker switch instead of toggle switch with Powerblock?
    3 Posts 3 Posters 1.8k Views
      just_jeepin
      Can I use an illuminated rocker switch (https://www.radioshack.com/products/spst-neon-rocker-switch?variant=5717521541) or illuminated toggle switch (https://www.radioshack.com/products/spst-12v-dc-illuminated-switch-4?variant=5717497925) instead of a toggle switch with the Powerblock?
      If so, would I just connect both the switch and led to the appropriate prongs?
      Thanks for any help!
        petrockblog Global Moderator
        It could work, if the LED inside the rocker switch is a 5V-LED. That is not clear from the description at that link, though. The illuminated switches have dedicated pins for the LED that you would attach to the LED pins. Take care for the polarity!
          genisdb
          Best Toggle switch I found on Amazon:
          https://www.amazon.es/gp/product/B01EA6KHK2/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
          It works great!
