Navigation
    • Search
    PowerBlock Power question
    ControlBlock, PowerBlock & Co.
    power block iot
    3
    5
    78
    • vabchgent
      vabchgent last edited by
      I just ordered a PowerBlock and need 5V and Ground only when PI is on for IOT switch. Are any of the connectors on the PowerBlock capable of putting out 5V only when the PI is on and remove the power when the PowerBlock is turned off.
      • petrockblog
        petrockblog Global Moderator last edited by
        Yes, the PowerBlock has dedicated 5V output pins that get powered when the RPi is switched and and are turned off, when the RPi is safely shut down.
        These pins are label with "+ OUT -" on the top side of the PowerBlock (see https://www.petrockblock.com/product/powerblock/).
        I hope that helps!
        vabchgent 1 Reply Last reply Reply Quote 0
        • vabchgent
          vabchgent @petrockblog last edited by vabchgent
          @petrockblog Thank you . One other thing how long does it usually take you guys to ship to US . I purchased one on Saturday I think.
          petrockblog 1 Reply Last reply Reply Quote 0
          • petrockblog
            petrockblog Global Moderator @vabchgent last edited by
            @vabchgent The orders are usually shipped within five working days. Shipping to the US then can vary between two and six weeks as I was reported from other customers. I keep my fingers crossed that your order arrives as soon as possible!
            • A Former User
              A Former User last edited by
              This post is deleted!
