    Pi 4B, ControlBlock and Max98306
    controlblockmax98306
    3 Posts 2 Posters 888 Views
      RSquaredPi
      Hi
      Looking to power a Max98306 from the 5V pin on the Controlblock. It will be connected to a Pi 4B. Will this work or should I be looking at a separate PSU for the amp? I was going to use the normal 27W Pi PSU.
        RSquaredPi
        Sorted.
          petrockblog Global Moderator
          It should work with the ControlBlock. It can provide up to 7 A.
