    ControlBlock power switch problem
    problem
    2 Posts 2 Posters 907 Views
    • W
      wolverine
      I built my raspberry with the ControlBlock in my SNES and connected the power switch. but i made the software setup with the switch turned off now the system boots the otherway arround (when i turn the switch to off it boots). can i restore it in the config? thx for your help
        petrockblog Global Moderator
        The configuration of the ControlBlock driver does not have an influence on this. Sounds as if the switch is wired backwards.
