    Question about roms? PLEASE HELP
    retropie 4.2
    4 Posts 3 Posters 1.0k Views
      Theimmortal
      So I downloaded Zelda ocarina of time as well as major as mask and Mario 64. The roms run pretty good but I can see through certain objects during gameplay such as the lakes through walls in ocarina of time and major as mask. Is there a way to fix this? Is it because of the rom itself or should I overclock to 1.4? How do I go about fixing this because it's making the game almost unplayable. Thanks!*
      • HurricaneFanH
        HurricaneFan
        You don't need 2 different posts about this. Can you delete one of them?
          Theimmortal @HurricaneFan
          This post is deleted!
          • jonnykeshJ
            jonnykesh @Theimmortal
            @theimmortal Please don't spam the forum just because you didn't get a reply within 5 minutes. Plus you should maybe provide some of the information requested as to your set up and the emulator you are using.
            Edit: Don't bother, no one is going to help you with that attitude.
