    Custom configs for CRT using the built-in composite out
    crtcrt tv
    147 Posts 23 Posters 77.8k Views
      dimetrius @Sakitoshi
      @Sakitoshi Hi in retropie 4.6, the games "Final burn alpha" do not go into crt mode. Can you please see what the problem is. Many thanks
      SakitoshiS 1 Reply Last reply Reply Quote 0
      • SakitoshiS
        Sakitoshi @dimetrius
        @dimetrius the finalburn category indeed doesn't have a config created.
        I'm not planing on creating one either since I use the arcade category to group all the arcade games. but you can copy the contents of /configs/arcade/retroarch_crt.cfg to /configs/fba/retroarch_crt.cfg and /configs/fba/retroarch.cfg being careful of editing the directories to point to configs/fba instead of configs/arcade.
          tix
          Hey @Sakitoshi ,
          using your configs and support I already have a perfect setup for my CRT !
          The only thing not perfect are the vertical oriented arcade games..
          So since I have a new CRT I'm thinking to place it on it's side and build a verical only retropie setup just for those beautiful games :)
          So do you have any tips in this direction, or even better some ready made configs/images for us/me noobs ?
          Of course I should find a way to rotate emulation station and everything..
          SakitoshiS 1 Reply Last reply Reply Quote 1
          • SakitoshiS
            Sakitoshi @tix
            @tix there isn't really a trick to make vertical games work better (that I know of). at most I have a dedicated configuration files (arcade_tweaks.zip) to play vertical games without having to put your tv sideways.
              @Sakitoshi Hello There are a number of sony playstation games in the PAL region, an image with large black bars at the top and bottom. Please tell me exactly where in retroarch, in which section which line to set the value to 512. Thank you so much.
                Krullnar
                @Sakitoshi
                I really appreciate your efforts here. My results are perfect. Exactly what I had in my imagination.
                The only thing I ran into is that I had unusual height scaling issues with some games( SNES Dragon Quest I & II, Dragon Quest III, Ys IV, Ys V... all role playing games for some reason). I had to tinker with the scaling height to get those improperly scaled lines to go away. For some reason it ended up playing nice with just one pixel lower than the default height (2x) in your config.
                • I
                  IGA
                  Hello)
                  Could you tell me how ( if it possible) to run raspberry in PAL mode (sdtv_mode=2) with all emulaters configured for NTSC ?
