    Picade Theme (WIP)
    themethemesthemingthemes with vidpicade
    26 Posts 12 Posters 8.1k Views
      tiduscrying
      Got a picade for Christmas and I've been using this theme for it. It looks absolutely stunning! For whatever reason though, the latest update to Emulationstation seems to be causing a weird issue with the theme...? It looks almost as if there is a "light" mode or something? I've tried uninstalling and then reinstalling the theme, but it still has the issue. Any thoughts?
      alphatoanantA 1 Reply Last reply Reply Quote 0
      • alphatoanantA
        alphatoanant @tiduscrying
        @tiduscrying thank you for trying out the theme and yeah that is super odd. I haven't updated my version of emulationstation in a while so I'll try to get a test set up this weekend to see if I can work out what is causing this. Can you send over which version you are on (I gather the latest but just wanted to check)?
        Thank you for the heads up.
        My RetroPie Themes:
        Art Book https://github.com/anthonycaccese/es-theme-art-book
        Art Book Next https://github.com/anthonycaccese/art-book-next-retropie
        TFT https://github.com/anthonycaccese/es-theme-tft
          tiduscrying @alphatoanant
          @alphatoanant By the looks of it, I am running emulationstation 2.9.0RP. I am going to try and see if I can try to downgrade to a previous version... I can't remember what I was on before, but I had a sinking feeling I'd break something when I updated things.
            porkyshmorky
            Hi, first off thank you for this theme. I think this theme looks beautiful; clean and minimalist, and matches the aesthetics of the Picade perfectly.
            I’m using it as a base for my customized theme, and I’m happy with it so far, but I don’t understand why the stripes on background image appear to be dimmer (or more transparent?) than it should be in the carousel view. The stripes appear brighter, and true to color, which matches the bezel on my Picade perfectly when I select a system (e.g. Arcade, NES, GBA, etc.). Is there a setting that I’missing that’s causing the behavior?
            • alphatoanantA
              alphatoanant @porkyshmorky
              @porkyshmorky thank you for checking this out. I don't have my picade setup currently to test but 2 things I think to try are...
              1. In <feature supported="carousel"> I have a border graphic in place that sits between the system logo and the text that displays the number of games. Maybe try commenting that out to see if that is somehow dimming the stripes more than they should be.
              <image name="border" extra="true">
                          <origin>0.5 0</origin>
                          <path>./_inc/images/border.png</path>
                          <size>0.29296875 0.005208333333333</size>
                          <pos>0.5 0.1953125</pos>
                       </image>
              or
              1. In <view name="detailed,video"> I have a transparent faded background that sits over the text to fade it out into the image/stripes. Maybe try commenting this out and comparing system to detail view? (I wonder if this is somehow making it look brighter when not on the carousel view - would be totally odd but its worth a shot to check)
              <image name="gamelist-fade" extra="true">
                       <origin>0 0</origin>
                       <path>./_inc/images/gamelist-fade.png</path>
                       <size>0.09765625 1</size>
                       <pos>0.537109375 0</pos>
                       <zIndex>300</zIndex>
                    </image>
              I'll see if I can get my picade setup this week to test out other options but hope this helps for now.
              My RetroPie Themes:
                porkyshmorky
                I tried commenting out both, like you suggested, but the dimming is still happening. I’m thinking this is just a default behavior in EmulationStation.
