    Retropie system not showing up on ES
    themesretropie systemconfig
    5 Posts 2 Posters 999 Views
    • virginsteeleV
      virginsteele
      Hi All,
      I'm back to develop my theme and I realized that the ES portable on windows doesn't show the retropie system on the carousel. I have the latest update of ES portable and I tried with more recent themes and also with standard ones (carbon) but none of them show the config.
      Anyone has an idea why is it not showing up ?
        mitu Global Moderator @virginsteele
        @virginsteele said in Retropie system not showing up on ES:
        Because there is no RetroPie system in Windows, that system is specific to a RetroPie installation, which you don't have.
        virginsteeleV 1 Reply Last reply Reply Quote 0
        • virginsteeleV
          virginsteele @mitu
          @mitu there should be a way to style it... the other themes have it
            @virginsteele If you have a RetroPie installation, just copy the relevant information from /etc/emulationstation/es_systems.cfg, then copy also the /home/pi/RetroPie/roms/retropie folder to your Windows installation. Make sure to adjust your es_systems.cfg to point to your copied folder.
            • virginsteeleV
              virginsteele @mitu
              @mitu Great! thanks, it works.
