    Is it possible to stream retropie to twitch?
    30 Posts 8 Posters 19.2k Views
      RetroResolution
      Hi,
      I have my third and final part of the guide on recording (and using twitch) 90% complete; I'm sad to say it's been on hiatus due to a family tragedy. I aim to get back to it, if for no better reason than to take my mind somewhere else.
      I dislike releasing unpolished guides, but may have to if I cannot motivate myself sufficiently - maybe rework it at some better time.
        RetroResolution @lwszolek
        @lwszolek to be honest I'm not sure how the pi 2 will handle native capture - this entire project has been undertaken on a pi 3 @ 1350mhz; on less demanding emulators it's likely to be okay. Further tweaking the ffmpeg config to trade quality for speed is also an option.
        • L
          lwszolek @RetroResolution
          @RetroResolution - I am sorry to hear you're going through a hard time right now. Online tutorials are not a priority next to RL. If you don't get around to finishing the guide, can I peek at the unfinished version? If you like, I can help edit it or something like that.
          Good to know about the pi3. I do have one of those lying around also, so if I can't get the pi2 at least working with nes emulator (my goal), I'll try that one.
          R mediamogulM 2 Replies Last reply Reply Quote 1
            @lwszolek thanks for your support, it helps!
            I did manage to complete another chunk of the guide - it's not been helping that the on-line editor keeps crashing under the strain (relatively complex layout for a WordPress page)
            I will try and get this finished tonight - lost two days trying to install visual studio on Windows 7...
            I'm happy to give you a copy to look at if I don't get it published today or tomorrow.
              mediamogul Global Moderator @lwszolek
              @lwszolek said in Is it possible to stream retropie to twitch?:
              I hate to hear this as well. Your guides are always a pleasure to view, right alongside Herb's and Floob's and I look forward to seeing more anytime you feel like producing them.
                RetroResolution @mediamogul
                @mediamogul thanks for your support, I do appreciate it.
                  RetroResolution
                  I've finally published the guide... I hope that you find it helpful - please feel free to ask me any questions (as I've not had time to polish it quite as much as I'd like)
                  Details are on the forum post here:
                  https://retropie.org.uk/forum/topic/2394/how-to-guide-recording-live-gameplay-in-retropie-s-retroarch-emulators-natively-on-the-raspberry-pi-and-twitch-streaming
                  A direct link to the guide is here:
                  Recording Live Gameplay in RetroPie’s RetroArch Emulators Natively on the Raspberry Pi
                  • Z
                    zerojay
                    Has anyone actually succeeded with streaming to twitch? I just get Retroarch crashing with a bus error when I attempt.
                      RetroResolution @zerojay
                      @zerojay I've not succeeded yet, as Twitch requires a specific x264 video and planar format; the trick to getting it working will be to use ffmpeg as a command-line tool to transcode some existing video file; this allows lots of tests with different configurations to be made without slow, tedious launching of Emulation Station, then dropping back to the terminal to make changes (this is how I worked out the settings for recording).
                      I have a link somewhere to a thread in which the Twitch codec requirements are discussed; it's on another machine, but I'll update this post to include it as soon as I can.
                      [Edit]
                      The link I was looking for is:
                      http://libretro.com/forums/showthread.php?t=115
                      The example Twitch settings as found on the thread can be seen, below. The main issue is that the video codec is libx264 and the pix_fmt must be yuv420p. In the code I use to record to disk, the video codec is libx264rgb with pix_fmt set to bgr24
                      I spent an evening looking into this, but have not been able to directly ouput to yuv420p using any x264 codec. It may be necessary to recompile the ffmpeg library to include some alternative x264 codec library (one which directly supports output to yuv420p).
                      The ffmpeg documentation does mention (somewhere...) commands to interrogate a given code to see which pix_fmts can be used.
                      vcodec = libx264
                      pix_fmt = yuv420p # twitch only supports yuv420p
                      scale_factor = 2 # Upscales with 2x to preserve chroma
                      acodec = libmp3lame
                      audio_global_quality = 75
                      sample_rate = 44100
                      format = flv # Flash muxer
                      video_crf = 25 # -crf
                      video_tune = animation # -tune
                      video_preset = superfast # -preset
                      threads = 3 # x264 threads
                        selsine
                        For anyone that's still following this, I've found some FFMPEG settings that work:
                        vcodec = libx264
                        acodec = libfdk_aac
                        pix_fmt = yuv420p
                        threads = 2
                        scale_factor = 1
                        format = flv
                        video_preset = ultrafast
                        video_profile = main
                        video_bufsize = 512k
                        video_minrate = 512k
                        video_maxrate = 512k
                        video_r = 60
                        video_g = 120
                        video_keyint_min = 60
                        sample_rate = 44100
                        audio_preset = aac_he_v2
                        audio_global_quality = 1
                        You can read more about it in my post: How To Live Stream To Twitch from a RetroPie
