    Using MAME Overlays/Bezels and shaders with RetroArch in RetroPie
    124 Posts 29 Posters 134.7k Views
    • FloobF
      Floob @Higgy
      @Higgy
      Its a good point about the aspect ratio on some such as Donkey Kong. I created the configs based on the original PC versions posted here, and in the first post you can see some caveats:
      http://libretro.com/forums/showthread.php?t=5085
      • I have tried to standardize each overlay, but this was not possible due to differing bezel artwork sizes. But I have kept the aspect ratios as correct as I can.
      • All glass screen bezel artwork, with a few exceptions made by me (Bombjack, etc..) are from Mr. Do!'s Arcade website on Mameworld, all credit goes to him for these.
      • Each machine overlay comprises of around 15 layered images, including glass effects, dust, dirt, room lighting reflection, arcade backdrops, cardboard monitor bezels, wells gardner monitor image, etc..
      • Each machine is presented as if you are stood directly in-front of the machine looking directly at the screen. Only the screen itself is not tilted away from you like a real machine as this would be a bit impractical on a flat PC monitor.
      • ALL shaders provided do require tweaking per machine, but I just haven't had the time. I personally like a glow effect, scanlines, curved screen, slight desaturation - PC emulation looks to saturated IMO. These are not required, feel free to use own preferred shaders.
      • Each overlay is made to be used with roughly 70-80% opacity. Again, adjust to suit personal tastes. 100% will give maximum reflection effect, but also more faded washed-out look.
      • ALL overlays are 1080p only. They may scale, but don't have the monitor to test, only a 1080p monitor.
      If you convert the images from 1080p to 1440x900 that will inherently have a slightly different aspect ratio, so you may find you need to tweak each config to compensate for the resized viewport area - although that sounds like what you are doing.
      As there are many configs the same in the games, I guess you could do a search and replace without opening files, like https://findandreplace.codeplex.com/ or similar. Then you'll see from timestamps whats left.
      Or you could get clever with Poweshell: https://technet.microsoft.com/en-us/library/ee692806.aspx?f=255&MSPPError=-2147217396
      • H
        Higgy @Floob
        @Floob
        Thanks for the find/replace info. For some reason it would not accept finding/replacing the 4 lines about image size & location, so I had to do it one line at a time. Anyway all sorted now.
        I could not get my head around Powershell - I don't do programming so it was tricky for my brain.
        I was wondering why some *.zip.cfg have figures for scaling the image, but the location is X=0 Y=0?
        There are lots of files, so did you just miss a few? Looking at their *.PNG Overlays, having a 0 & 0 does not look right. In this case I dropped on a rectangular box onto the Overlay in GIMP and used those coordinates for the location.
        I would be testing it tonight, but after getting the ROMSET I am having difficulty unzipping it to get the additional ROMS you have created Overlays for. I am now using 'PeaZip' and it seems to be doing something. Just slow with 30GB to process!!!!
        • H
          Higgy @Higgy
          @Floob - things have been progressing well. I have it all working in principle. A few tweeks needed here and there on the configs.
          Once finished would you like the files for 1440x900 ? They would be best with you to advertise so to speak. As I said i am sure lots of people are using PC monitors with this resolution.
          I am now concentrating on the hardware build - a 2-player bartop.
          Sounds in RetroPie menu had noise via 3.5mm jack so I am using USB soundcard.
          For controls I am using 2x Minimus32 boards (aka KADE) which will be setup as keyboard button presses.
          The overlays look so good. And having a widescreen monitor it is a great way of feeling immersed without those darn black side boarders ;)
          FloobF edmaul69E 2 Replies Last reply Reply Quote 0
          • FloobF
            Floob @Higgy
            @Higgy Glad to hear things are working well.
            It would be good to add the 1440x900 images and configs to the video tool, but I'm thinking that they would be fairly large?
            The download is already 500MB and I really need to update the tool to call down the images if needed, so I'll need to find suitable hosting for that as well.
            It would be good to eventually add a complete MAME bezel set, but I think its all about finding the time.
              ruxton_bruce @Floob
              @Floob I'm trying this with retropie 4 and i'm experiencing a strange behavior. When i open a game without bezel, it opens the settings of the last game with bezel. For instance if I open Asteroids and then Street Fighter II, i get the bezel from Asteroids on Street Fighter. I have seen others having the same problems. Is there a fix for this with Retropie 4. I have tried updating retropie just today and the problem still exists. The above worked fine for me on Retropie 3 it just started happening when I updated to Retropie 4.
              Any help much appreciated
              • FloobF
                Floob
                @ruxton_bruce
                Can you paste you /opt/retropie/configs/mame-libretro/retroarch.cfg file into pastebin?
                • H
                  Higgy @Floob
                  @Floob Sizes of new files is 330mb.
                  I am using Retropie v4.0, but I have transferred the files manually. As I am only testing I don't think I have opened a ROM which does not have a bezel, so I can't comment on @ruxton_bruce issue.
                  I have the bartop all painted, so hopefully soon I can crack on with the fun part of assembling it all together and wiring in the buttons :)
                  • GreenHawk84G
                    GreenHawk84
                    Hello,
                    I started a topic but nobody seems to know - is there a way to do system specific bezels like Sega Genesis and Super Nintendo? This way whenever I run a console core I can just have the Sega bezel or Nintendo bezel? I run on a 16:9 monitor with 4:3 aspect on most games, so the sides would look nice with something there.
                    For Arcade, I can set the bezels as game-specific?
                    FloobF 1 Reply Last reply Reply Quote 0
                    • FloobF
                      Floob @GreenHawk84
                      @GreenHawk84 Sure, you just specify the overlay in the system specific retroarch.cfg file.
                      Like this:
                      • GreenHawk84G
                        GreenHawk84
                        @Floob , thank you. Do you happen to know of any good SNES, NES, Genesis, NEO-GEO, ETC, bezels to apply to a system?
                        • FloobF
                          Floob
                          I use the packaged ones here:
                          https://github.com/biscuits99/rp-video-manager
                          GreenHawk84G T 2 Replies Last reply Reply Quote 0
                          • GreenHawk84G
                            GreenHawk84 @Floob
                            @Floob that's strange, a lot of them are labeled as different ones but are actually the same old TV image.
                            Even better, how can I make my own bezels? I would definitely crank some out with photoshop if I had a template/guidance.
                              tien_huu_1408 @Floob
                              @Floob Have you released any new update on rp-video-manager?
                              • GreenHawk84G
                                GreenHawk84
                                This one is pretty cool, great example:
                                http://www.gameex.info/forums/uploads/monthly_06_2015/post-680-14345093699168.jpg
                                • FloobF
                                  Floob @GreenHawk84
                                  @GreenHawk84 Check out the posts here:
                                  http://libretro.com/forums/forumdisplay.php?f=11
                                  • Z
                                    Zigurana @Guest
                                    (Spammer is gone, thanks!)
                                    • GreenHawk84G
                                      GreenHawk84
                                      These bezels in the video are pretty much exactly what I want:
                                      They look like they are a part of the screen you are using instead of a photo of another screen.
                                        ruxton_bruce @Floob
                                        @Floob Hi Floob
                                        I have setup Attract mode and it looks great. My only problem is that the Bezels/Overlays don't work in Attract Mode. They work fine when run from Emulation Station just not from Attract Mode. Is there something else I need to set in Attract Mode for the Bezels/Overlays to work?
                                        Cheers Floob
                                        • FloobF
                                          Floob @ruxton_bruce
                                          @ruxton_bruce Its most likely the config of your emulator setup in AM.
                                          Post one on pastebin, and I'll check it.
                                          An example is
                                          http://pastebin.com/raw/GcrQGLcP
                                            ruxton_bruce @Floob
                                            @Floob Hey there Floob. Thanks for the reply.
                                            Here is the mame.cfg from Attract Mode
                                            http://pastebin.com/j6jNaBFE
                                            Cheers again for all your help Floob
