    LED button lighting
    led button
    2 Posts 2 Posters 245 Views
      Carraudio
      I have searched a bit to see if anyone has tried this. I’m a novice when it comes to this stuff but I’m sure someone can figure this out.
      I’m currently working on a arcade cabinet. It will have led lit buttons. What I would like to figure out is how to light up just the buttons that are used for the system you are playing. So for example if you are playing NES only the A&B buttons are lit up, or for SNES ABXYL&R buttons are lit.
        Clyde
        If you're using an Ultimarc Pac-Drive, check out this:
        https://retropie.org.uk/forum/topic/4126/howto-led-control-with-a-pac-drive
