    lr-vice and Vic-20, Plus/4, C128, and Commodore Pet
    lr-vicevic20plus4c128pet
    14 Posts 6 Posters 3.4k Views
    • rkosterR
      rkoster
      I just got Vic-20 & Plus/4 working with lr-vice, and am in the midst of compiling C128 and expect it to work too.
      git clone https://github.com/libretro/vice-libretro.git
      followed by
      make EMUTYPE=xvic
      make clean
      make EMUTYPE=xplus4
      did the trick to get the cores, then I copied them to lr-vice alongside the C64 core, added /vic20 and /plus4 folders, edited emulators.cfg for each, and so on, the usual emu add process, and both of them booted right up.
      Seems like it'd be easy to add Plus/4, Vic-20, and I expect, C128 to RetroPie in the experimental section. Or (probably better) have them be installed by lr-vice's scriptmodule. That would give substantially the same behavior as standalone Vice in RetroPie, I think.
      Pet is more of a challenge; there's no Makefile.xpet in vice-libretro. I'd check SourceForge and see if I can copy or generate (I think it's generated) from standalone Vice, but it looks like SourceForge is undergoing maintenance tonight.
      Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
      • rkosterR
        rkoster
        Sure enough, vice_x128_libretro.so also compiled and booted just fine.
        • U
          upmost777
          @rkoster said in lr-vice and Vic-20, Plus/4, C128, and Commodore Pet:
          make EMUTYPE=xvic
          I am a noob and have been looking for a walk-through to set up a C128. This was as close as I found. Any suggestions?
          • rkosterR
            rkoster
            If you are a noob, then my suggestion would be to install the standalone Vice (not the lr-vice core which this post is about). It automatically installs a c128 emulator, I believe. I forget the exact name though.
            Then you'd basically add a new system to Emulationstation; see https://github.com/RetroPie/RetroPie-Setup/wiki/Add-a-New-System-in-EmulationStation for instructions on that.
            Sorry I can't offer more detailed help; busy day at work. :)
            • rkosterR
              rkoster
              I got the Commodore PET working. It involved source code work to support it as a libretro core, though.
              My fork of lr-vice with support for PET is here: https://github.com/raphkoster/vice-libretro
              git clone https://github.com/raphkoster/vice-libretro.git
              make clean
              make EMUTYPE=xpet
              sudo cp vice_xpet_libretro.so /opt/retropie/libretrocores/lr-vice
              Then add it to es_systems.cfg:
                <system>
                  <name>pet</name>
                  <fullname>Commodore Pet</fullname>
                  <path>/home/pi/RetroPie/roms/pet</path>
                  <extension>.crt .d64 .g64 .prg .t64 .tap .x64 .zip .vsf .CRT .D64 .G64 .PRG .T64 .TAP .X64 .ZIP .VSF .p00 .P00</extension>
                  <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ pet %ROM%</command>
                  <platform>pet</platform>
                  <theme>pet</theme>
                </system>
              then create /opt/retropie/configs/pet, (I just copied the c64 folder) and put this in emulators.cfg:
              lr-xpet = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-vice/vice_xpet_libretro.so --config /opt/retropie/configs/pet/retroarch.cfg %ROM%"
              default = "lr-xpet"
              I haven't figured out controls or anything, but games boot. Keyboard seems rather wonky -- punctuation is all weird. Might just be a default setting to a different language. I don't want to submit an upstream pull request until it gets banged on some more, though. Maybe someday we can have C128, Vic-20, Plus/4, and PET as full installs in RetroPie. :)
              @BuZz, I've had no luck so far in getting libretro upstream to notice my pull requests. Is there a channel to use other than github?
              • rkosterR
                rkoster
                Turns out that the original PET keyboard doesn't have numbers on the top row! Only the numbers on the numpad work. That explains what I was seeing.
                There are some models that used the "business keyboard"; 4032B is one example that does have number keys, though much of the punctuation is in different places. I bet the B models specifically mean that keyboard.
                Also, the later models seem to default to 80 column; you probably don't want to use them for games for that reason.
                  paradadf @rkoster
                  @rkoster join them on discord and tell them about your PRs. Sometimes they are too busy/distracted than don’t really pay attention.
                  • rkosterR
                    rkoster
                    The PET support has been merged upstream.
                    To get all these additional machines, though, would involve getting RetroPie to add them to the build script the way they are for the regular Vice emu, I think?
                      mitu Global Moderator @rkoster
                      @rkoster It might be just as easy as adding them to the runcommand menu - is that what you're referring to ?
                      rkosterR 1 Reply Last reply Reply Quote 0
                      • rkosterR
                        rkoster @mitu
                        @mitu The lr-vice scriptmodule only compiles the C64 core. The way Vice works is that you compile each of the different machines separately. So the scriptmodule would need to compile Vic-20, Plus4, C128, and now Pet.
                        The standalone Vice scriptmodule already installs all of them, I think.
                          The following patch should do the trick:
                          --- a/scriptmodules/libretrocores/lr-vice.sh
                          +++ b/scriptmodules/libretrocores/lr-vice.sh
                          @@ -22,7 +22,8 @@ function sources_lr-vice() {
                           function build_lr-vice() {
                               make -f Makefile.libretro clean
                          -    make -f Makefile.libretro
                          +    make -f Makefile.libretro
                          +    make -f Makefile.libretro EMUTYPE=xpet
                               md_ret_require="$md_build/vice_x64_libretro.so"
                          @@ -31,6 +32,7 @@ function install_lr-vice() {
                                   'vice/data'
                                   'vice/COPYING'
                                   'vice_x64_libretro.so'
                          +        'vice_xpet_libretro.so'
                          @@ -42,5 +44,6 @@ function configure_lr-vice() {
                               chown -R $user:$user "$biosdir/data"
                               addEmulator 1 "$md_id" "c64" "$md_inst/vice_x64_libretro.so"
                          +    addEmulator 0 "$md_id-xpet" "c64" "$md_inst/vice_xpet_libretro.so"
                               addSystem "c64"
                          • rkosterR
                            rkoster
                            Yes, but you may as well add
                            make -f Makefile.libretro EMUTYPE=x128
                            make -f Makefile.libretro EMUTYPE=xplus
                            make -f Makefile.libretro EMUTYPE=xvic
                            since they also all work.
                            • tomi7711T
                              tomi7711
                              Hi!
                              Try yape if you like Commodore Plus/4. On Raspberry Pi3 works perfectly.
                              https://github.com/calmopyrin/yapesdl
                                shift
                                Has anyone managed to make Cartridges work for Vic-20? With Vice there is the possibility to add the -cartgeneric parameter, but I tried with lr-vice and it doesn't work.
                                • J JimmyFromTheBay referenced this topic on
