    Powerblock Pi4 Power Supply Connector
    pi 4busb cdrivers
    3 Posts 2 Posters 659 Views
      garyt977
      Re: Powerblock Pi4
      Hello! I received the PowerBlock I ordered on 9/12, which is supposed to be compatible with the Pi4. However, the USB power supply for the Pi4 is USB C, which is not the connector on the PowerBlock. Can I use an adapter without blowing up anything? Also, do the drivers need to be installed before installing the hardware? Thanks! (apologies if this has been asked before, but I could not find it in the forums.)
        petrockblog Global Moderator
        You can either use a USB micro cable and according power supply or use a USB C cable with a USB micro adapter. Both is possible and you will not blow anything!
        You should install the drivers after installing the hardware.
        Hope that helps!
          garyt977 @petrockblog
          @petrockblog Thanks so much!
