    driver sdl, udev for dual adaptator cable, dual input card (xin mo dual)
    2 Posts 2 Posters 772 Views
      alexis-puska
      Hi all,
      I have an idea and a purpose. Some poeple in the world of retropie/recalbox/pibox have a lot a problem with xin mo dual card, dual adaptator psX to usb (lot of cable) who recognise only one pad of the 2 port of the cable/card. the only solution it's to modified Mame/NeoGeo/emulationStation and some driver for split all adaptator connected to declare 2 pad. What are you think about a config files in the retropie project for list cable/adaptator/card with 2 port on it, and a modified driver who can consult this list to map 2 controler automatically. i have the problem because i have an dual adaptator cable PSX to usb but i can't configured 2 pad on it, i can fix it to modified the udev driver like it's done with the xin mo card. but it's not very well, all pad connected have the same functionnemnt after.
      The solution purpose it's to declare in file the name of controller who wants to split, in emulation station when we declare this controller (2 pad on it) We configured the pad 1 and the pad 2 just after.
      I think it's requierd a lot of time of development but if some developper look this we can make it really fast.
        pal57
        Yes! I have the same issue. It would be great if there was a fix for it!
