    tag to remove system help
    emulationstaiontheme
    6 Posts 3 Posters 450 Views
      andreamav
      hello everyone,
      is there a way "not" to display the emulationstation "system help" bar ?
      I know you can disable it from the emulationstation menu ...
      but from the "theme code" is it possible to disable it?
      Thanks in advance...
      chicueloC 1 Reply Last reply Reply Quote 0
      • chicueloC
        chicuelo @andreamav
        @andreamav you can edit the theme xml and move out of screen
          andreamav
          ok... in this case is the same of metadata..
          i believe or guess there is something like extra or true / false tag to choose ... is it possible?
          • cnotoC
            cnoto
            Are you talking about the on-screen help? If so, there is an easy uncheck box in the UI settings of the Main Menu accessible from the start button.
              andreamav @cnoto
              @cnoto said in tag to remove system help:
              exactly.
              i would like to know if is there a possibility to do this by my own theme by default. (not by emulationstation menu)
                andreamav
                a not good solution is use this:
                <helpsystem name="help">
                <fontPath>./_res/fonts/TitilliumWeb-Regular.ttf</fontPath>
                <fontSize>0.035</fontSize>
                <origin>0 0</origin>
                <pos>1 1</pos>
                </helpsystem>
                but i would prefer to hide the help, but allow the user to reactivate it from the menu if he wants.
