    RetroArch Help Request :
    pi 4 retroarch
    21 Posts 4 Posters 600 Views
    • E
      escc1986
      I'm not sure what I did
      But I absolutely did something wrong to my
      RetroArch for my Flycast core
      Every Dreamcast game I attempt to play my controller is not configured ... it disabled my ability to exit games with select and start :(
      It only happens when I play any Dreamcast game (not any other console or system )
      May I ask
      How do I uninstall RetroArch for my Dreamcast
      So I can reinstall it again (only on the Dreamcast RetroArch )
      Hope someone is able to help
      simpleethatS 1 Reply Last reply Reply Quote 0
      • simpleethatS
        simpleethat @escc1986
        @escc1986 From RetroPie Setup:
        Manage Packages -> Manage Optional Pacakges
        Scroll down to lr-flycast and then select Remove
        • E
          escc1986 @simpleethat
          @simpleethat
          I actually already tried that
          I uninstalled it and re installed it
          It didn't do anything
          Any other advice
          • simpleethatS
            @escc1986 did you change the default emulator from lr-flycast to reicast? press a button when the gray runcommand box pops up when loading a game and make sure it's using the proper emulator. Other than that I'm not really sure. Somebody else around here certainly knows more than me.
            • E
              escc1986
              no i didn't change the default emulator
              thank you for the kind advice
              i just tried to add more roms to test unfortunately no roms seem to be working on flycast
              hope someone will help ?
                @escc1986 said in RetroArch Help Request ::
                Please add some info about your system when opening up a support request, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
                Check your \\retropie\configs\dreamcast folder and rename the retroarch.cfg file present there, then re-install the lr-flycast package. This should reset the RetroArch configuration to default for the dreamcast system.
                • E
                  escc1986 @mitu
                  @mitu said in RetroArch Help Request ::
                  retroarch.cfg
                  sorry a little confused .. May I Ask What Do i Rename ?
                  and what do i rename it to ?
                  thank you for the help
                    ReadyPlayaWon Banned @escc1986
                    mitu said to rename retroarch.cfg file .. and name it anything you like.
                    personally i would recommend rem-retroarch.cfg ...
                    and then when you re-install the lr-flycast package it will generate a brand new retroarch.cfg file
                    if everything is working after that ... then just delete the rem-retroarch.cfg file
                    • E
                      escc1986 @ReadyPlayaWon
                      @ReadyPlayaWon said in RetroArch Help Request ::
                      rem-retroarch.cfg
                      thank you for the clarification, i will try that now
                      • E
                        escc1986 @escc1986
                        @ReadyPlayaWon
                        did exactly as said ... still not working properly ... enter the game game ... the start and select doesnt function as a exit .... and cant press select and y to access the menu gui for retroarch , like for other games ...
                        not sure what to do from here
                          any way you can send me your retroarch.cfg ? (so i can copy and paste )
                          this is all there is ... but there are a bunch on mappings in the /opt/retropie/configs/dreamcast/mappings folder (image below)
                          input_remapping_directory = "/opt/retropie/configs/dreamcast/"
                          • E
                            @ReadyPlayaWon
                            thank you for that
                            you absoultly right , not much i can do ...
                            should i remove the all/retroarch.cfg
                            or
                            should i do a fresh clean start ?
                              No, you shouldn't - this will break the other systems that are working right now.
                              Please provide the info asked in https://retropie.org.uk/forum/topic/3/read-this-first and also a detailed (verbose) log from running a dreamcast game, as mentioned in that topic.
                              • E
                                escc1986 @mitu
                                Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) : pi 4 B
                                Power Supply used: (If using a Pi) Official power supply 5.1 3A
                                RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.6
                                USB Devices connected: keyboard , Nes Controller , dolphin bar
                                Controller used: NES controller
                                Error messages received:
                                Verbose log (if relevant):
                                Parameters:
                                Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-flycast/flycast_libretro.so </dev/null --config /opt/retropie/configs/dreamcast/retroarch.cfg "/home/pi/RetroPie/roms/dreamcast/_Naomi Rail Shooters/ninjaslt.zip" --appendconfig /dev/shm/retroarch.cfg
                                [CDROM] No sg devices found and sg kernel module is not loaded.
                                /opt/retropie/supplementary/runcommand/runcommand.sh: line 1255:  1989 Illegal instruction     /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-flycast/flycast_libretro.so --config /opt/retropie/configs/dreamcast/retroarch.cfg "/home/pi/RetroPie/roms/dreamcast/_Naomi Rail Shooters/ninjaslt.zip" --appendconfig /dev/shm/retroarch.cfg < /dev/null
                                Emulator: (Name of emulator - if applicable) ir-flycast
                                  This post is deleted!
                                  • E
                                    escc1986
                                    @ReadyPlayaWon
                                    good advise to back up the sd every week or so ;)
                                    will keep that in mind
                                      mitu Global Moderator @escc1986
                                      This is not a verbose log, just a normal log file. Make sure you toggle verbose logging in the runcommand launch menu when starting the game.
                                      • E
                                        escc1986
                                        @mito where do i find in ssh the Verbose log ?
                                          @escc1986
                                          from the runcommand menu select "L" Launch with verbose logging
                                          then using WINScp or PuTTy ... ssh into RetroPie and then log file is in
                                          /dev/shm/run/runcommand.log
                                          output will look something like this ... (i'm running Guilty Gear Isuka using lr-flycast)
                                          Parameters:
                                          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-flycast/flycast_libretro.so </dev/null --config /opt/retropie/configs/atomiswave/retroarch.cfg "/home/pi/RetroPie/roms/atomiswave/ggisuka.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                                          [INFO] RetroArch 1.8.5 (Git 8bcd74b)
                                          [INFO] Redirecting save file to "/home/pi/RetroPie/roms/atomiswave/ggisuka.srm".
                                          [INFO] Redirecting savestate to "/home/pi/RetroPie/roms/atomiswave/ggisuka.state".
                                          [INFO] Capabilities:  NEON VFPv3 VFPv4
                                          [INFO] Built: Apr 20 2020
                                          [INFO] Version: 1.8.5
                                          [INFO] Git: 8bcd74b
                                          [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-flycast/flycast_libretro.so"
                                          [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/Flycast/Flycast.cfg.
                                          [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/Flycast/atomiswave.cfg.
                                          [INFO] [Overrides] game-specific overrides found at /home/pi/.config/retroarch/config/Flycast/ggisuka.cfg.
                                          [INFO] Config: appending config "/home/pi/.config/retroarch/config/Flycast/ggisuka.cfg"
                                          • E
                                            @ReadyPlayaWon
                                            thank you for explaing , its late here need to get some rest , will report back here in the morning
