    Can fan be connected to output
    power supplyfanpins
    2 Posts 2 Posters 693 Views
      scott1176
      I had a fan for my Pi4, which uses pins 1 and 14. If the Powerblock is installed can I solder + - to the voltage output. Has anyone done this, and does it draw too much power?
        petrockblog Global Moderator
        Hi!
        Yes, in general, that is possible. I know from several customers that they did exactly that.
