    Help me understand - PowerBlock vs. GPIO shutdown
    powerblockshutdown
    3 Posts 2 Posters 897 Views
      ccie38296
      Hello! Building a new Retropie machine using a Raspberry Pi 4. I currently have it set up to startup/shutdown using a button across pins 5/6 (GPIO3 I believe that is). I have the dtoverlay-shutdown feature enabled, and by default a momentary press of the button will re-wake the Pi from halt when it has been shut down by the button.
      I'm curious what advantage the PowerBlock has over the method I'm using. I want the power control for my cabinet to utilize a switch or button, rather than software menu options. I see PowerBlock enables use of a toggle switch. Does it do anything else that makes it more attractive for Retropie cabinet use than the GPIO method? Is it a "cleaner" shutdown in some way?
      Thanks!
        petrockblog Global Moderator
        Hi! In comparison to the dtoverlay the PowerBlock offers some subtle additions. However, it certainly depends on your specific needs if they are important for you or not:
        • The PowerBlock completely cuts the power supply of the Raspberry Pi after it observed a complete shutdown of the Raspberry. The dtoverlay drives the Raspberry into a standby-mode, still letting the 5 and 3.3V pins powered.
        • The PowerBlock can handle momentary and toggle buttons. In case of a momentary button it provides a "hard reset" function by pressing the button longer than 5 seconds.
        • The PowerBlock provides a system state indication via its status LED pins. Booting, Running, Shutdown are indicated by different signal patterns.
        • Upon observed shutdown request via the attached button at the PowerBlock, a custom shell script can be executed for.
        I hope that helps. Let me know if you have any further question!
          ccie38296 @petrockblog
          @petrockblog Excellent, thank you for the information!
