    Finalising RetroPie Questions
    24 Posts 6 Posters 7.6k Views
      jay81uk
      Ok, so I've almost finished my setup! Just had a few more questions though relating to this...
      Scraping... I have over 1000 games and didn't realise I had to scrape each one manually! Is there a quicker way?
      How do I find out how much space I have left on my Pi's Micro SD card?
      Saving games... how do I save my progress if I've played an hour of a NES or SNES game?
      Finally, how do I delete roms from the retropie?
      briankrossB 1 Reply Last reply Reply Quote 0
      • briankrossB
        briankross @jay81uk
        @jay81uk said in Finalising RetroPie Questions:
        Use Steven Selph's Scraper
        In terminal type:
        df -h
        Look up linux commands for more info.
        This depends on the emulator used. NES, SNES.
        SSH or FTP
        Yep.
        • Brian
          jay81uk
          That doesn't show how to save games though? As for the scraper, I have no idea what I'm supposed to do there?
            BuZz administrators
            instructions are in the documentation https://github.com/retropie/retropie-setup/wiki/scraper
            also
            • briankrossB
              briankross @jay81uk
              Like I mentioned it depends. If you give me specifics I can be more specific. Generally there are two ways to save games, in game as if it's the original hardware, and by using snap shots (save states) with RetroArch. Try this.
              Go here and scroll down to Steven Selph's Scraper.
              • Brian
                jay81uk
                I will be using Nes, Snes, Gameboy and Sega
                • briankrossB
                  briankross @jay81uk
                  Each emulator may have a different way to save, if it was possible to save to begin with based on the game. What you need to do is pick an emulator for each of the systems you plan to use and go from there. Emulators that start with lr- are RetroArch, so there can be two ways to save as previously mentioned.
                  For example, I play The Legend of Zelda on NES, using the lr-nestopia emulator. I'm able to save in game as if on the original hardware with the gamepad. On the backend, the emulator saves a .srm file in the /roms/nes directory. This file can also be backed up and transferred. When I play The Legend of Zelda on NES again, I go to the game saves as in game I would normally if on the original hardware, the emulator reads the .srm file, and I see all of the saved games, select, load, and play.
                  How to save games in RetroPie / RetroArch is worth a read. (Floob is amazing!)
                  Generally speaking, try using in game save / load first after playing for a few min or the next checkpoint etc. then just try it and see if you can save / load. If possible, use a RetroArch emulator. Test this before spending hours expecting to save your progress, maybe the game never had saves to begin with, or maybe something isn't configured.
                  • Brian
                    jay81uk
                    @briankross I'm just using the emulators that came with Retropie though.
                    Games that allow in game saving, like Mario World 2 on the Snes... when I save, will the save be there as it is on the physical console?
                    I guess systems like NES are different though... how would I save and load state? When I load a rom, there's no option...
                    • briankrossB
                      briankross @jay81uk
                      Okay, try this for NES so you get the idea: (you may need a keyboard)
                      1. Select your system (NES) in Emulataion Station
                      2. Select a game and launch
                      3. Look for a small screen that comes after that and press a button on your gamepad (B or A). This takes you in to a screen where you can select the emulator for this specific game or all games. Select lr-nestopia for all games (NES).
                      4. Now select, launch
                      5. Play the game a bit, and save in-game
                      6. Exit the emulator by pressing both Select and Start (feature of RetroArch, by the way)
                      7. Re-launch the same game, ignore the grey box screen
                      8. See if you can load the previously saved game using the game menu, try Start or Select if you need to.
                      9. Did it work?
                      After step 5, you can FTP to your rPi and see if there is a [romname].srm file in your opt/home/pi/RetroPie/roms/nes/ folder. If there is, you're golden.
                      • Brian
                      • Beretta9B
                        Beretta9
                        This post is deleted!
                          jay81uk
                          @briankross But how do I save in game? On NES titles, you could never save...
                          • briankrossB
                            briankross @jay81uk
                            Edited
                            The Legend of Zelda, press Start, saved games are displayed.
                            When you die in Zelda, you have the option to Continue, Save, or Retry. Other games may work differently.
                            Take a moment and try the thing...
                            • Brian
                              jay81uk
                              @briankross I just tried a NES game - Mario Bros. Couldn't find anywhere to save...
                              • briankrossB
                                briankross @jay81uk
                                Mario Bros. was never able to save. Try a game that can save, like The Legend of Zelda.
                                • Brian
                                  jay81uk @briankross
                                  @briankross Oh ok, I presumed you could still save via a snapshot or something.
                                  • briankrossB
                                    briankross @jay81uk
                                    I was referring to one method of saving, as if you're on the original hardware.
                                    You may be able to use save states if using an emulator that starts with lr- (RetroArch). Go to the RGUI menu and save states by pressing Select+X on a SNES controller. Check out RetroArch Configuration and RGUI.
                                    Give it a whirl.
                                    • Brian
                                      bobcat987 @briankross
                                      @briankross said in Finalising RetroPie Questions:
                                      Give it a whirl.
                                      More specifically, you can quick save/load with select + R and select + L, respectively, on all retroarch emulators (which is most of the default ones). You can read a bit on hotkey settings here https://github.com/retropie/retropie-setup/wiki/RetroArch-Configuration, it's a worthwhile read. Of course you can remap hotkeys if the defaults don't work for you.
                                        jay81uk @bobcat987
                                        @bobcat987 Are all the default emulators Retroarch then? So on my SNES controller, what would I press as I manually configured it via the setup in retropie.
                                          jay81uk
                                          @bobcat987 Can you help? Thanks
                                            PetroRie
                                            Why not using quick saves? They're much better. You can save and load anytime you want. First you need to make a directory which is going to hold all the save files, I made mine in the ROMS folder. I called it SAVE and within this folder I made two separate folders, one called SAVE_FILES and other SAVE_STATE. Open retroarch.cfg and add the path of the save folder to the following line:
                                            savefile_directory = "/home/pi/RetroPie/roms/SAVE/SAVE_FILES/"
                                            savestate_directory = "/home/pi/RetroPie/roms/SAVE/SAVE_STATE/"
                                            Also add these following lines to your retroarch.cfg file:
                                            input_enable_hotkey_btn = "8"
                                            input_state_slot_decrease = "left"
                                            input_state_slot_increase = "right"
                                            input_load_state_btn = "6"
                                            input_save_state_btn = "7"
                                            The numbers in my example are linked to the corresponding buttons of my PS4 controller. I think your's will be different but it won't be hard to figure it out. You can get the button ID's from the controller file which is located at:
                                            /opt/retropie/configs/all/retroarch-joypads/
                                            Or if you're using Windows:
                                            \RETROPIE\configs\all\retroarch-joypads
                                            Sometimes it's a pain in the butt but once it works it works flawless.
