    Problem transferring roms to thumb drive
    retropie4.7usb flashdrive
    35 Posts 2 Posters 4.2k Views
      mitu Global Moderator @Drdave79
      @Drdave79 Run the next command from WinSCP (copy the command and paste it there) just like you've run the previous mount command:
      sudo mount -o bind /home/pi/extra/psx /home/pi/RetroPie/roms/psx
      then restart EmulationStation and see if your PS1 games show up.
        Drdave79 @mitu
        @mitu said in Problem transferring roms to thumb drive:
          So, back to the 1st question - do you have a psx folder under /home/pi/extra ? The error seems to hint that there's no such folder.
            Drdave79 @mitu
            @mitu On the usb drive, yes. /home/pi/extra/psx. All of the roms are in there.
              Hm, I think I've got the command wrong. Try this:
              sudo mount --bind /home/pi/extra/psx /home/pi/RetroPie/roms/psx
              and restart EmulationStation. If that works, replace the mount command from autostart.sh accordingly and see if it works after a reboot.
              #... rest of the commands from `autostart.sh`
              emulationstation #auto
                Drdave79 @mitu
                Unfortunately still not working:
                This is the USB drive path:
                Also, after moving all of the roms to the USB drive, the home/pi/RetroPie/roms/psx folder on the SD card is empty. Does that matter?
                  @Drdave79 said in Problem transferring roms to thumb drive:
                  Try adding the command directly in autostart.sh.
                  No, it doesn't.
                    Drdave79 @mitu
                    @mitu No change :(
                    This is where I got the UUID from. Assuming I got the 1808-1615 correct.
                      Yes, that's correct - the output from the mount command showed that /home/pi/extra is correctly mounted from the external disc.
                      No idea why it's not working, the usbromservice uses a similar approach to mount the roms folder (i.e. mount --bind).
                        Drdave79 @mitu
                        @mitu Alright. I appreciate your trying to help. I'll move the roms back to the sd card. Please let me know if you think of anything else.
                        Thanks again.
