Cyvern Problems
I'm aware this has been discussed before, but I cannot find the solution.
I cannot get Cyvern the Dragon Weapons to launch. I have tried many methods, and it will not work. Examples I have tried would be Mame 2003plus, 2003, 2010 Advmame several versions. FPa... and 7 romsets with 2 Skns bios's. I've been looking for the Advmame version which works with advmame 1.4 So I hear.... but no luck. Anybody have any advice on this?
Retropie 4.8
Pi 3b+ -
@Novabug
Are you using the official RetroPie image from this site?
Do you know for which emulator is your romset intended?For example:
I tried this romcyvern.zip
from the MAME2003 reference set on my Pi 3B+ with Retropie 4.8 just now using MAME2003 and it works for me just fine.Here are the checksums for the files in my rom zip.
CRC32 Size Name -------- ------------- ------------ DDC8C67E 4194304 cv200-00.u16 A6CB3F0B 4194304 cv101-00.u20 7486BF3A 4194304 cv210-00.u18 F8A0FBDD 1048576 cvj-odd.u8 802FADB4 1048576 cvj-even.u10 CD4AE88A 4194304 cv100-00.u24 65863321 4194304 cv201-00.u13 FBEDA465 4194304 cv300-00.u4 7E2B836C 524288 sknsj1.u10 -------- ------------- ------------
This same romset should work in MAME2003, MAME2003 Plus, and MAME2010 since all those reference sets have the same files and checksums.
@Novabug said in Cyvern Problems:
but no luck
Picking romsets/emulators combination at random is indeed just relying on luck, you should follow the documentation instead : https://retropie.org.uk/docs/Validating%2C-Rebuilding%2C-and-Filtering-ROM-Collections/
While language might not be very important on shmups, note that the US version of this game was only dumped back in 2011, earlier versions of mame can't run it. The emulation of that game also had tile priority (meaning gfx) issues until 2008.
@YFZdude That set I have, but for some reason will not work. I newer version wont run on older mames.
Well, as @barbudreadmon mentioned, you do need to match the emulator and romset you try to use. They won't work if you mix them. Decide which emulator you want to use, then find the rom for it from the romset meant for that emulator.
Did you install Retropie yourself?
If so, what method did you use to install it? -
Ah yes, I see the commit here
https://github.com/libretro/mame2015-libretro/commit/02b0e179390fb8fb78106759fed7a5b91a8f6741
Wonder if this could be used in mame2003+, how noticable are these priority issues? I'm unfamiliar with this game.
@arcadez2003 thoughts?
@mahoneyt944 said in Cyvern Problems:
Not sure, i only learnt about this old bug while checking if the game had many dump revision. Furthermore i only played it in FinalBurn which i think never suffered from this.
The train is mentioned in that commit, so i'd suppose it might be affected by this problem.
