    Running a custom rom with lr-mame*
    lr-mame2003pluslr-mameimagescustom romslibretro core
    32 Posts 3 Posters 4.7k Views
    • eberhabE
      eberhab
      [EDIT] A quick recap of the thread on running non-arcade-custom-roms with retropie using the Olivetti M20 as an example:
      Launched in 1982, the Olivetti M20 was probably the first 16-bit personal computer in Europe. While running M20 floppy images is possible with mame, it does not work OOB with RetroPie, since it needs some additional/ custom options: One needs to tell mame to boot up the m20 driver and which of it's two floppy drives to put the rom in. Mame uses so-called softlists to identify driver and floppy arguments based on a list of known roms, but those don't work OOB either. Of the many mame versions available on RetroPie, only two can be used: mame (standalone), and lr-mess (libretro core, containing mame's non-arcade drivers). A few manual steps are still needed:
      1. Installing M20 support on Retropie (automatic):
        Use theadd-mamedev-systems script to automize the setup of mame-type emulators (more details in this thread).
        Download the script manually into: /home/pi/RetroPie-Setup/scriptmodules/supplementary/.
        Then call it from RetroPie-Setup -> Configuration / tools -> add-mamedev-systems (Install mame, lr-mess, and m20 from "systems with default settings" submenu).
      2. Installing M20 support on Retropie (manual steps, skip this if you used add-mamedev-systems):
        Install mame and lr-mess from RetroPie-Setup (experimental packages).
        Configure your new emulator types in /opt/retropie/configs/m20/emulators.cfg which support softlist, or passing the driver type and floppy arguments (more details in this thread below).
        Add the new emulator, dedicated roms folder and supported rom suffixes (zip, img, imd, td0, cmd) to /opt/retropie/configs/all/emulationstation/es_systems.cfg.
      3. Floppy images/ roms/ bios
        Place (zipped) m20 floppy images (roms) into ~/RetroPie/roms/m20, place bios file into ~/RetroPie/BIOS/mame/
        Good starting points are:
        giochi (crc da3a87aa) - To start the games type the first two letters of their name (bd, ma, ca, te, to)
        spiele+uhr (crc ea2c4765) - Set date and time to something pre 2000s, or cancel the autostart with ctrl+c and launch the games menu by entering run "spiele"
        startrek_en (crc 10564b94)
      4. Double check if the ROM is OK (This is an M20 specific step and not needed for other systems)
        Most ROM's will fail to autostart their software and show a command line, or refuse to boot entirely. These roms are likely missing some header which was lost when originally reading the physical floppy. You can confirm the header (floppy track 0) is missing, if the following command only shows zeroes:
        hexdump <image> |head -n 1
        If this is the case, you can easily copy the header from another working image (e.g. pcos102) on linux/ retropie console:
        dd conv=notrunc if=pcos102.img of=<image> bs=4096 count=1
        Changing the header will make mame show a checksum error when using softboot, but them rom will still start.
      5. Running the M20
        If you set up your environment with add-mamedev-systems you should find an new m20 machine in emulationstation. Launch roms from there as usual. The launch menu offers no default, multiple preconfigures emulators to choose from:
        A good starting point is the lr-mess-m20-flop1 emulator. This will put any bootable rom into the M20's first/ right floppy drive, which is the default.
        If your rom if softlisted, the lr-mess-m20-basename emulator can be used. Make sure the *.zip file name corresponds to the softlisted software name.
        If you are using custom cmd launch options (see 7.) you have to launch with the lr-mess-cmd emulator.
        You might have to play around with the keyboard for a bit as the layout depends on the language of the OS on the rom. A few tips can be found in FAQ.
      6. EmulationStation theme (optional)
        Cygnus Blue Flames theme has art support for the M20.
      7. Custom options (optional)
        For more flexibility, one can create custom launch files (*.cmd) in the m20 roms folder.
        To boot into msdos, one needs to choose a different bios setting, so the coressponding *.cmd file could look like this:
        m20 -bios 1 -flop1 msdos.img -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/m20/
        To e.g. boot more than one image (the M20 has two floppy drives) one can load a bootable system in floppy drive 1 and then load a second rom in floppy drive 2. The custom.cmd file would look like this:
        m20 -flop1 <bootable-image> -flop2 <custom-rom> -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/m20/
      8. A few notes: When booting directly into the M20 operating system PCOSone can just type the name of the program to be loaded. The disk contents can be shown with vl 0: or vl 1: for floppy 1 and 2 respectively. If vl fails with "ERROR 92" the rom is missing the vl tool or some header information. This article/ website explains how to fix this, describes emulation of the M20 with mame in more detail, and contains some more in depth knwoledge about the M20 in general.
      [Original question]
      Hi all, I am trying to run a custom rom with lr-mame, and so far I am failing to specify the machine name, which I can do with stand-alone mame.
      In more detail:
      The rom I am trying to run is a custom "M20" floppy image. Stand alone mame runs the image well by specifying machine type and machine arguments (e.g. mame m20 -flop1 %ROM%)
      With libretro cores, I do not seem to have the option to pass along machine type and arguments. Looking at lr-mame2003-plus for example, all supported roms seem to be listed in its mame2003-plus.xml file, in which the necessary settings (including machine type to be used) are made.
      Is it possible to somehow pass machine type and machine related arguments to lr-mame* (e.g. lr-mame2003-plus) cores? Or would it make sense to try to add my specific rom to their romlist xml file? Any other suggestions on how to run a custom rom/ specific machine floppy image with libretro core emulators? Thanks!
        @eberhab said in Running a custom rom with lr-mame*:
        lr-mame contains only the arcade 'drivers' from MAME, you'd probably want lr-mess for running a non-arcade system, in which case AFAIK the folder name is used as the driver for the core.
        eberhabE 1 Reply Last reply Reply Quote 0
        • eberhabE
          eberhab @mitu
          @mitu Thanks very much for the tip! I had not heard about lr-mess before, it looks promising. Unfortunately the documentation in the wiki is quite sparse. I am having trouble to figure out how to set up the folder structure to define the driver and how to pass the floppy argument to the core. So far it's a lot of trial and error with no real luck.
          The first sentence of the wiki article about mess reads that mess was actually merged into mame in v0.162 in 2015. While I am eager to explore this option, I am trying to achieve a more portable solution and lr-mess does not seem to be available (any more?) as a core in other retroarch releases beyond retropie.
          Is there any other libretro mame core which supports "all" mame drivers and can somehow be freely configured beyond the set of known games? I have looked through the sources on github for some of the mame-libretro projects and it seems that lr-mame2016 does at least contain the code to support the machine that I am looking for [1]. This makes me think that, if it has not been excluded on build time, there might a way to "trick" lr-mame into loading this rom, by somehow passing the right driver/ arguments?
          Thanks for your help!
          [1] https://github.com/libretro/mame2016-libretro/blob/master/src/mame/drivers/m20.cpp
            In this case, I'd recommend using MAME directly and add your own system for M20. Upstream MAME is available in RetroPie in the experimental section and contains both arcade and MESS/systems drivers. You can have full control over the command line parameters this way.
            No, the libretro cores derived from various MAME versions are always split (lr-mess for current MAME and lr-mess2016 for the 2016 MAME version).
            EDIT: I'm going to refer you also to this topic created by @folly, which may be helpful with setting up lr-mess for various systems which are not supported OOB by RetroPie.
            • F
              Folly @eberhab
              @eberhab
              I tried M20 for you and I could run msdos20, only when selecting bios 2.0f and using an alternate cpu selecting in the mame-gui.
              Be aware that this driver is a preliminary driver so it can be hit and miss.
              • eberhabE
                eberhab @Folly
                @Folly Thanks for looking into this! What are the steps you took to start the rom? Via standalone mame, or via lr-mess?
                Concerning the m20 itself, it should be ok, I am using it successfully on retropie since a few years, running it with standalone mame. I can also pass along different bios options on the commandline with no issue.
                What I am trying to achieve is running m20 roms via a libretro core, so I started looking into lr-mess. Here I cannot add arguments via cmd, but specify via an xml config file. I feel like I am half way there, but I am not sure how to properly set up the directory structure. So far I have:
                • Added my custom rom properties to ~/RetroPie/BIOS/mame/hash/m20.xml
                • Created a rom folder ~/RetroPie/roms/m20
                • Added my floppy image/ rom as well as m20 bios files to the created roms folder
                • Running /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so --config /opt/retropie/configs/mame-libretro/retroarch.cfg /home/pi/RetroPie/roms/m20/games.img --verbose
                It starts up mame with m20 driver successfully, it finds the game properties in the modified xml file, but it does not find the game image itself. So I am still doing something wrong with the folder structure. So far I am hesitant to use the add-mamedev-systems script, since I would like to first understand the necessary steps myself and be able to launch from the cmdline.
                F 2 Replies Last reply Reply Quote 0
                • F
                  Folly @eberhab
                  Ok, that's a good sign.
                  Adding arguments is possible but it can only be done by adding single quotes.
                  You can use my script as @mitu suggests.
                  When selecting m20 it will generate a module script and install the default options.
                  After the install you can find the loaders in /opt/retropie/configs/m20/emulators.cfg
                  Here is an example :
                  lr-mess-m20-flop1 = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/m20/retroarch.cfg --appendconfig /opt/retropie/configs/m20/retroarch.cfg.add -S /home/pi/RetroPie/roms/m20 -s /home/pi/RetroPie/roms/m20 -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so 'm20  -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/m20/ -cfg_directory /opt/retropie/configs/m20/lr-mess -c -ui_active -flop1 %ROM%'"
                  If you need a separate install with extra bios options I can try and make an extra menu item for m20 in the menu-item : systems with extras.
                  Let me know what options you normally add to mame and I can have a look.
                  • F
                    Folly @eberhab
                    @eberhab
                    I was also able to run pcos102.
                    I discovered that the hash table states that you have to use the command vl to list the disk content.
                    It also states that you can launch .cmd files from the command-line-prompt.
                    Do you know how to run a program from pcos ?
                    Edit :
                    I was able to run mazedaze.cmd from gamesd ( booting with pcos102).
                    Just entered mazedaze.
                    • eberhabE
                      eberhab @Folly
                      @Folly Single quotes! That's awesome! Thanks a lot for your help @Folly and @mitu. I figured out the directory structure and with what I learned about lr-mess and adding custom arguments, I can now run my m20 images with libretro. Then I tested your script, which makes the setup process a lot easier. The default options for the m20 work well for me, my disks do not need custom bios settings.
                      What's left to do now for me is to figure out how to map some of the keyboard keys from the m20 to the vitual gamepad.
                      Concerning the M20 itself, if you are interested, you can find a lot of information, including commands, images, and even new games on: http://www.z80ne.com/m20/
                      Basically you can run applications from pcos by just typing the app name, or you can switch back and forth between pcos and the basic interpreter by entering "basic" and "system" commands respectively.
                      • eberhabE
                        eberhab @Folly
                        @Folly After setting up the m20 with add-mamedev-systemsdo I have to modify es_systems.cfg myself, or can the script do that too? I see some menu options for es and artwork, but I am not entirely sure how to proceed.
                        EDIT: Also, which of the emulators the script creates did you use to test mazedaze from gamesd? I have some trouble getting the keyboard to work. I can use it to access the mame menu, but I cannot type into the console.
                        The script seems to disable softlist mode and passes all arguments like driver and floppy to lr-mess via command line. Does this mean that I can use custom floppys without having to add them to the m20.xml hash table?
                        • F
                          Folly @eberhab
                          No, that's not needed.
                          Just like any other module-script that is installed it will add the entry in es_systems.cfg.
                          Just have a look.
                          We have predefined gamelists with media for some categories and for some systems. If you select that option all predefined gamelists with media will be downloaded to the specific roms/<a system directory> directory. It's downloaded over there so other gamelists/media, in the regular directory, is not overwritten. If somehow you have gamelists/media already in the roms/<a system directory> then you should backup them first.
                          M20 is not there, so if you want to make some than you can share it over here :
                          https://retropie.org.uk/forum/topic/32188/creating-es-gamelists-with-media-for-mame-lr-mame-lr-mess
                          Artwork is a selection of artwork for mame standalone mostly containing the handheld categories.
                          It's downloaded in the regular artwork directory for mame standalone. If you have already artwork then you should backup them.
                          These arwork files also contain overlays for lr-mess. So there is and option to create overlay configs for lr-mess and extract bezels and backgrounds for these lr-mess overlay-configs.
                          The first config file will be placed next to the rom and will refer to other overlay configs in the normal retroarch/overlay directory.
                          If you have files over there that you want to keep then you have to backup them.
                          I used the example I gave you earlier.
                          You have to enable a hotkey_disable_key in the retroarch.cfg otherwise hotkey's will get in the way.
                          Also the keyboard will not exactly react like mame standalone.
                          For typing mazedaze I switched back and forth between keyboard=emulate and keyboard=natural in the mame-gui.
                          That way I was able to use and find the correct keys to run mazedaze.
                          The non-basename loaders will indeed disable softlist-mode so you will be able to use custom floppies without editing the xml's.
                          Btw.
                          For our project we use the cygnus-blue-flames theme which has many exotic themes. If you want to add m20 you can discuss it here :
                          https://retropie.org.uk/forum/topic/29961/request-for-artists-working-on-themes-needs-for-lr-mess-mame-additions
                          • F
                            Folly @eberhab
                            @eberhab
                            Would be nice if games booted with some autoboot function.
                            Do you know if that is possible ?
                            • eberhabE
                              eberhab @Folly
                              @Folly Perfect, again thanks a lot for all your help and the additional info :)
                              I did not find an entry for the m20 in the es_systems.cfg, but the file had been edited by hand before, so I'll try to run the installer again and/ or start with a fresh setup.
                              Concerning the autoboot I see two options:
                              • You can rename the file you want to run into an INIT.* file with the fm (filemove) command. e.g. fm mazedaze.cmd INIT.CMD. This means that you have to modify the disk image which afaik only works unzipped and with mame > 0.212
                              • From retropie one should be able to supply autoboot commands e.g. -autoboot_delay 5 -autoboot_command "mazedaze\n" They could be supplied by calling a custom *.cmd file rather than the rom itself?
                              Would it make sense to update the RetroPieWiki/Emulators/MESS article to mention add-mamedev-systemsand to briefly describe the setup? Also a link from the general MAME article pointing to MESS probably could be helpful, too.
                              Here is some preliminary artwork for the M20 if you want to have a peak. I am using it with std carbon theme, will have a look into the thread you suggested.
                              I'll continue to debug the issues that I currently have, mainly with the keyboard not working as expected and the lr-mess core crashing every other time I run it on my pi2 (so far it works fine on the pi4).
                              EDIT: If it is interesting for people I could imaging to compile a list of cmd files to start different games. Providing modified images does not feel like the right way to go, since we'd be creating duplicates of existing images with different checksums, which potentially increases confusion and makes it harder to get all available images integrated into the hash tables.
                              • F
                                Folly @eberhab
                                That's a good one.
                                Then you will be able to experiment and see where the files go. If you feel confident enough you can use it on your existing image.
                                For many things I added help, so check that.
                                If you feel that some help has to be added then let me know and I will see if I can add some text.
                                Ok, thats a nice one.
                                Would be nice if there are disks with only 1 game that will autostart. Would be an addition if they were also in the mame soltlist but that will probably never happen.
                                For a few system I added such autoboot loaders to be installed. So if 1 disk contains more games then the disk can be duplicated and renamed in order to load the game automatically. However with this system the gamedisk needs pcos first so you still need swapping the disks.
                                You can have a look in the systems with extras menu-item for the autoboot installs.
                                That would be the goal, however the script is still 3rd party.
                                So not part of the official RetroPie work, therefor it should not be added yet.
                                Ok will have a look.
                                The specs of the pi2 are too low would use the pi4 indeed.
                                • F
                                  Folly @eberhab
                                  In the mame-gui of the latest mame (now 250) you can select a disk-image.
                                  While doing that you can choose that changes are written to a new disk-image.
                                  Insert a new name and now all changes will be written in the new image.
                                  I changed a basic file with succes.
                                  • eberhabE
                                    eberhab @Folly
                                    @Folly Again thanks a lot for adding the nice artwork to the cygnus-bf theme!
                                    Just a quick summary of what I did the past days and what I found out so far concerning automating the loading process of M20 images.
                                    Most of the discs actually have the pcos included, so the need to launch with two floppies might not really be there. I looked closer into your example with mazedaze where you booted the virtual m20 with pcos102. It seems that mazedaze is actually on the "giochhi" image file (it's the entry just aboved the "gamesd" disk in the hash file). The giocchi disk boots up fine all by itself, with no need for a separate pcos disk. You should be able to try yourself. Then disk then boots into an italian start screen where you can make your choice. The issue with the keyboard here are mainly origination from the underlying pcos being italian.
                                    Concerning the "gamesd" disk, the situation is a bit more complicated. I matched the checksum from the hash table with the file that circulates the internet, and this is a "broken" images, which is missing some header data in order to work in the m20. I have described how to fix this in an article about M20 emulation on z80ne.com (you can verify with sha1sum and hexdump). The image can be fixed easily by transplanting the missing header from a working image file (e.g. from pcos102). If you are not on linux, in any case I have uploaded a fixed image into the [dropbox folder] from my previous post. The fixed image should then also boot right away in flop1 with no need to load an additional pcos disk. The keyboard should also work better since the underlying pcos is german.
                                    Both images booth with -bios 0 so also here luckily there is no need to make custom settings. The only issue with bios settings I see with the msdos image, which indeed needs a different bios setting. Its not a game though, so maybe it's no loss if msdos would not be available oob.
                                    Overall I think the mamedev systems installer should work with most disks oob, as long as people use working images. One could think about a way to let people know if the image has a missing header, since it seems to be the case for most of the circulating images unfortunately.
                                    F mituM 3 Replies Last reply Reply Quote 0
                                    • F
                                      Folly @eberhab
                                      Thanks for the reply.
                                      I have that one also.
                                      Indeed loading directly into an Italian menu.
                                      Didn't know what I had to enter though, but translation has been activated by my script, just pressing HOTKEY T and it will translate.
                                      So loading worked by entering two letters of the game to be loaded.
                                      Concerning the "gamesd" disk, the situation is a bit more complicated. I matched the checksum from the hash table with the file that circulates the internet, and this is a "broken" images, which is missing some header data in order to work in the m20. I have described how to fix this in an article about M20 emulation (you can verify with sha1sum and hexdump). The image can be fixed easily by transplanting the missing header from a working image file (e.g. from pcos102). If you are not on linux, in any case I have uploaded a fixed image into the dropbox folder from my previous post. The fixed image should then also boot right away in flop1 with no need to load an additional pcos disk. The keyboard should also work better since the underlying pcos is german.
                                      Earlier on I had also a qwertz keyboard layout, that is a German one I think.
                                      Will try your fix. ( LOADS PERFECTLY NOW !)
                                      Theoretically it should be added to mame somehow.
                                      msdos needs an other bios and another cpu board and will run when selected.
                                      But basically I don't think it's very interesting as msdos can be executed better on other devices or in other emulators.
                                      Good to know that the default install will work for most !
                                      A gamelist with video could be made explaining in the video how to run or whether a disk is bad or not.
                                      • F
                                        Folly @eberhab
                                        @eberhab
                                        Can you make a summarise in you first post of this thread ?
                                        I think that would be a good thing, don't you think so too ?
                                        Then I can add a link in my tread on how to run m20.
                                          mitu Global Moderator @eberhab
                                          If you are not on linux, in any case I have uploaded a fixed image into the [dropbox folder] from my previous post. [...]
                                          Please don't post links with/to ROMS/BIOS/other copyrighted material.
                                          • eberhabE
                                            eberhab @mitu
                                            @mitu Good point, thanks. I'll remove the content. Anyone should be able to fix the public images with the info from the linked article.
                                            @Folly Will think about a summary. Might make sense to get the images fixed first and try to get the hashes updated in mame.
