    Theme Question - Variables (Color variable based on System)
    themeingvariables
    2 Posts 2 Posters 144 Views
    • N
      NewYears1978
      Hey all, new to Emulation Station and theming and all this.
      Learning a little about variables. I have some images that I color with colors in the theme. I would like to have those colors change based on the system.
      How would I set up variables by system for colors that can then be called with one variable?
      Basically just assume I have an image called that is a straight line and shows on my system view. I want to color it with the color variable that says, hey this is SNES so use the SNES color.
      Thanks in advance.
      Edit:
      I should add that I know how to make a variable such as <snescolor>ffffff</snescolor> and then apply that with snescolor, but I would still have to create a little repeated code batch for every system like that.
      Didn't know if there was a way to use an ifsubset type command kind of how you say ifsubset="system" but for specific systems or some other way.
        Maybe 'nested' variables would work ? See https://github.com/RetroPie/EmulationStation/pull/703
