8bitdo Zero Gamepad mapping problem
Hey my config does not look like that.
If i edit the controls from nes and access retroarch from there I could get it to work.
But I have two controls so it only works in input 2.
Saved the settings, restarted and settings gone :/ -
Please complete this:
https://retropie.org.uk/forum/topic/3/read-this-first -
@frudda
I have this delicious 8Bitdo Zero GamePad :DI always start it with R+Start to play on RetroPie or on Android.
Here is my config file:
https://raw.githubusercontent.com/meleu/share/master/8BitdoZeroGamePad.cfgAs far as I know if the 8bitdo hack is on, it should deal with it correctly, but I got this controller before the 8bitdo hack and solved this way (I'm assuming you are comfortable with linux commands and know how to edit retroarch.cfg-like files):
- configure your 8Bitdo Zero controller to be the player2 (
input_player2_joypad_index
). - configure a working joystick as player1 (
input_player1_joypad_index
). - launch any game with RetroArch.
- invoke RGUI (Select+X on player1 joystick).
- go to
Settings
->Input
->Input User 2 Binds
- configure the buttons as you like (hey look!! the buttons are working!!!)
- go back to the RGUI Main Menu.
- select
Save New Config
. PAY ATENTION AT THE BOTTOM LEFT CORNER OF THE SCREEN AND MEMORIZE THE FILENAME SHOWED THERE! - go to the shell prompt
- open the file saved on step 8 (you memorized the filename, right?)
- write down the numbers after every
input_player2_BUTTON-NAME_btn
(substitute BUTTON-NAME with: a, b, y, x, l, r, start, select, l2, r2. You will notice that the numbers are the default number +11). - open the file
/opt/retropie/configs/all/retroarch-joypads/8BitdoZeroGamePad.cfg
(substitute CONTROLLER-NAME with the obvious). - put the numbers you wrote after their respective
input_BUTTON-NAME_btn
(note that there aren't that playerN string here). - save this file.
- start a game to test it.
BONUS TIP: it's a good idea to disable select+start to exit the emulator! These two buttons are very close to each other in 8Bitdo Zero and you can accidentally press them together.
Thank you for a very detailed guide.
The input information I put into the 8BitdoZeroGamePad.cfg
I could also read my saved Arch file from putty, and the mapping is the same as your config file
Now the 8Bitdo Zero Gamepad always connect as #1 strange thing is it dont seem to read from the 8BitdoZeroGamePad.cfg even thought it should, but it is connect as #1. my other controller got index #0 but shows conntected as #1
If i change controller to the right player number in Arch it dosnt help -
my config files
8BitdoNES30Pro.cfg
http://pastebin.com/M431a1Jx8BitdoZeroGamePad.cfg
http://pastebin.com/F7hu60yQ
tested index 1-2retroarch.cfg
http://pastebin.com/PF3tjCRP -
@frudda said in 8bitdo Zero Gamepad mapping problem:
8BitdoNES30Pro.cfg
http://pastebin.com/M431a1JxThe 3rd line is wrong (missing
sign) and is unnecessary here:input_player1_joypad_index "0"
You should remove it from this file. The
input_playerN_joypad_index
should be set in the retroarch.cfg file, not in the joystick buttons mapping one.8BitdoZeroGamePad.cfg
http://pastebin.com/F7hu60yQThe 1st line is unnecessary here:
input_player2_joypad_index = "2"
Remove it too. Same reasons above.
retroarch.cfg
http://pastebin.com/PF3tjCRPYou are using
config_save_on_exit = "true"
. This is a certainty that there will be confusion at some point. :-)
Do you really need it? -
One issue there is your retroarch.cfg has been saved over, looks like you have set it to save on exit
That will cause issues.
Thanks guys, i will report back in the morning.
I can take a fresh retroarch.cfg and replace it
then fix the index config and remove it from the gamepads config
Reason why I used config_save_on_exit is because i wanted full screen on all games
but I guess its better to add it specific on top in nes folder retroarch.cfg config file. -
@frudda You can set video output using the configuration editor.
https://github.com/retropie/retropie-setup/wiki/Configuration-Editor -
retroarch.cfg is now back to normal and full screen changed in configuration editor
I added
input_player1_joypad_index = "0"
input_player2_joypad_index = "1"
in retroarch.cfg
they are removed in controller cfgI also removed the detected from boot on bluetooth.
I start the NES 30 Pro first
after Zero Gamepad.In Nes its working controller 2 now if i check retroarch input2 in Nes game. The input is declared. but wonder if its my old settings here
Because if I switch to snes and play controller 2. All buttons is not working and have wrong buttons on input2 declaredNow both controllers are detected as port #1
Changed
input_driver = "udev"
To
input_driver = "sdl"On configs including controller cfg, now it works!
The retroarch on "udev" reconfigure the controller i guess to wrong mapping?Found this post
https://retropie.org.uk/forum/topic/192/8bitdo-fc30-pro-works-in-es-but-not-retroarch/14Thanks to everybody
