    [GUIDE] Retropie + 3.5 inch RPi LCD v3.0 (no brand)
    retropie 4.0.23.5 lcd rpiwaveshare
    29 Posts 22 Posters 74.0k Views
      sword_sea
      Hello fellow humans. Ive gotten mine to work, though the colors are a bit wonky. can someone tell me the code for rotating the screen 180 degrees? I would like to use it on it's side for convenience reasons.
        Bio_C @sword_sea
        @sword_sea You should change the string in the /boot/config.txt file
        to: dtoverlay=waveshare35a:rotate=180
        Didn't try it myself, but that's what is says in the waveshare readme file.
          dkajan
          Hello I have only black screen...please help me
            SeaFlurry02
            That sudo cp waveshare-dtoverlays/waveshare35a-overlay.dtb /boot/overlays/waveshare35a.dtbo command wont work for me! All i get is the command prompt yelling "cp: missing destination file operand after {former command here}"! Anyone know how to resolve?
            • samcoS
              samco
              @SeaFlurry02 just happen to be working on this too. There is a "o" missing in the copy try sudo cp waveshare-dtoverlays/waveshare35a-overlay.dtbo /boot/overlays/waveshare35a.dtbo
              • H
                hohodsj
                Thank you a million!!!
                The only thing I modified was
                to
                sudo cp waveshare-dtoverlays/waveshare35a.dtbo /boot/overlays/waveshare35a.dtbo
                  slowplayer157
                  Hey thank for the code and it works great for a kit i pick up on Ebay, it wasn't that difficult to follow along with, and it's great that i had come across this. This is such great help, and understood what you mean by " this is very important because most guide are for 3.2 inch so if u have the waveshare 3.2 u must exchange the word "waveshare35a " in "waveshare32b" so when you mean if you have a 3.2 inch change "waveshare35a " to "waveshare35b" and if you have a 3.5 inch keep it at waveshare35a
                  • jtkblueJ
                    jtkblue
                    is there a way I can switch between HDMI and LCD screen?
                      dariofavaron
                      Thanks it worked.
                      The emulator was not centered in the picture so i had to change the resolution under RETROARCH -> Settings -> Video and width and height. it was 12807someting and i put the resolution of the screen 480320
