    Run ROMs from USB flash drive instead of microSD card - manual
    flash drivemicrosdroms
    21 Posts 6 Posters 15.2k Views
      Kreibich
      How to run ROMs from USB drive easily:
      1. login to retropie SSH with PuTTY or similar SSH client: ([http://www.putty.org/](PuTTY official web page)) - in Windows command prompt type: "putty retropie" or use IP address instead of "retropie".
      2. log in as: pi / retropie
      3. run these commands in retropie shell:
      sudo mv /home/pi/RetroPie/* /media/usb0/
      sudo rm -rf /home/pi/RetroPie/*
      sudo ln -s /media/usb0/* /home/pi/RetroPie/
      sudo reboot
      Description:
      1. line - moves the folder with bioses and roms from microSD card to USB flash drive
      2. line - deletes the rest of files from microSD card that were unable to delete when moving files
      3. line - creates symbolic link from USB flash drive folder to microSD folder
      4. line - reboots your Raspberry Pi
      If everything is OK, you should be able to run your roms from USB now.
      herb_fargusH 1 Reply Last reply Reply Quote 1
      • herb_fargusH
        herb_fargus administrators @Kreibich
        @Kreibich probably more proper to mount the USB on the roms folder:
        https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
          Kreibich
          Yes, that's the other way... but it has the same result. It would be great if RetroPie developers would put this option in RetroPie settings... some kind of switch "MicroSD / USB flash drive", because a lot of people needs this.
            cyperghost
            https://retropie.org.uk/forum/topic/2582/can-my-usb-device-have-data-on-it-already/5
            No the result isn't the same if the USB flash drive is for example FAT32
            • RionR
              Rion
              I would highly recommend to "not" move /home/pi/RetroPie/* to /media/usb0/.
              This will likely break things in the long run.
              Instead just make a copy of the folder /home/pi/RetroPie/roms
              And place it on you usbstick "/home/pi/RetroPie/roms"
              First Disable USB transfer daemon
              • Enter the RetroPie Setup menu within the RetroPie menu in EmulationStation.
                Select Setup / Tools.
                Select usbromservice - USB ROM Service
                Disable USB ROM Service.
              • Step 1 – Plug In The Device
              The first step is to plug in your USB stick.
              • Step 2 – Identify The Devices Unique ID
              In order to find the unique reference (UUID) for your drive run the following command in the terminal :
              ls -l /dev/disk/by-uuid/
              The line will usually refer to "/sda*" and in this example it is “sda1”. My ID is “18A9-9943”. Note down yours.
              You would need to repeat this step if you wanted to use a different device as the UUID would be different.
              • Step 3 – Create a Mount Point
              A mount point is a directory that will point to the contents of your flash drive. Create a suitable folder :
              sudo mkdir /media/usbstorage
              I’m using “usbstorage” but you can give it whatever name you like. Keep it short as it saves typing later on.
              Make pi the owner of the mounted drive and make its permissions read, write and execute for it
              sudo chown -R pi:pi /media/usbstorage
              sudo chmod -R 775 /media/usbstorage
              Set all future permissions for the mount point to pi user and group (explanation can be found here)
              sudo setfacl -Rdm g:pi:rwx /media/usbstorage
              sudo setfacl -Rm g:pi:rwx /media/usbstorage
              • Determine the USB Hard Drive Format
              You also need to know the file system the drive is formatted with
              sudo blkid
              /dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="787C-2FD4" TYPE="vfat"
              /dev/mmcblk0p2: UUID="3d81d9e2-7d1b-4015-8c2c-29ec0875f762" TYPE="ext4"
              /dev/sda1: LABEL="retropie" UUID="18A9-9943" TYPE="`vfat"
              • Now mount the usb stick in there. If it is NTFS you will need to install some utilities first
              sudo apt-get install ntfs-3g -y
              • If the drive is exfat install these utilities
              sudo apt-get install exfat-utils -y
              • For all drive types mount the usb with this command, -o insures pi is the owner which should avoid permission issues
              sudo mount -o uid=pi,gid=pi /dev/sda1 /media/usbstorage
              • If you get an error use this syntax
              sudo mount -t uid=pi,gid=pi /dev/sda1 /media/usbstorage
              • Automount the USB Hard Drive on Boot
              /media/usbstorage will be the folder in which you store your media. We want it to be automounted on boot The best way to do this is through the UUID. Get the UUID by using this commmand
              sudo ls -l /dev/disk/by-uuid/
              • You will see some output like this. The UUID you want is formatted like this XXXX-XXXX for the sda1 drive. If the drive is NTFS it can have a longer format like UUID="BABA3C2CBA3BE413". Note this UUID, for me it is 18A9-9943
              total 0
              lrwxrwxrwx 1 root root 15 Jan  1  1970 3d81d9e2-7d1b-4015-8c2c-29ec0875f762 -> ../../mmcblk0p2
              lrwxrwxrwx 1 root root 15 Jan  1  1970 787C-2FD4 -> ../../mmcblk0p1
              lrwxrwxrwx 1 root root 10 Oct 26 21:10 18A9-9943 -> ../../sda1
              • Now we will edit fstab to mount the USB by UUID on boot
              sudo nano /etc/fstab
              • Add the line in red to the bottom, replace XXXX-XXXX with your UUID and exfat with your type if it is different (e.g. ntfs, vfat, ext4). You may or may not need the quotation marks wrapped around the UID, you do not need quotation marks wrapped around the file system type (ext4, vfat, NTFS etc).
              • The umask 0002 sets 775 permissions so the pi user and group can read, write and execute files on the external USB drive. To completely eliminate permission issues you can set the umask to 0000 which equals 777 permissions so anybody can read, write and execute. Note that 777 permissions are considered a security risk.
              • If you have issues here then try replacing uid=pi,gid=pi with just the word defaults (typical for ext4). You can also try replacing the UUID with the /dev/sda1 line.
              • This is an example for vfat
              `/dev/mmcblk0p1 /boot vfat defaults 0 2
              /dev/mmcblk0p2 / ext4 errors=remount-ro,noatime 0 1
              UUID=XXXX-XXXX  /media/usbstorage vfat   nofail,uid=pi,gid=pi   0   0
              • This is an example for exfat
              UUID=XXXX-XXXX  /media/usbstorage exfat   nofail,uid=pi,gid=pi   0   0
              • for NTFS, note that it is ntfs and not ntfs-3g
              UUID=XXXX-XXXX    /media/usbstorage    ntfs   nofail,uid=pi,gid=pi    0   0
              • for ext4 using uid and gid is not recommended so use at your own risk as it could cause issues
              UUID=XXXX-XXXX    /media/usbstorage    ext4   nofail,uid=pi,gid=pi    0   0
              • If you get any errors you can replace uid=pi,gid=pi with defaults or remove it entirely
              UUID=XXXX-XXXX    /media/usbstorage    ext4   nofail,defaults    0   0
              • For using /dev/sda1 and defaults if you have troubles with UUID
              /dev/sda1    /media/usbstorage    ext4   nofail    0   0
              • Now test the fstab file works
              sudo mount -a
              • If you didn’t get errors reboot, otherwise try the suggestions above to get it working then mount -a again until it succeeds
              sudo reboot
              You should be able to access the mounted USB drive and list its contents
              cd /media/usbstorage
              ls
              Every time you reboot, the drives will be mounted as long as the UUID remains the same. If you delete the partitions or format the USB hard drive or stick the UUID changes so bear this in mind. You can always repeat the process for additional hard drives in the future.
              If you have multiple hard drives you will have to make separate mount points (e.g. /media/usbstorage2) for each drive’s partition
              • Now that's done lets make a copy of es_systems.cfg
                It's located in this folder
              /etc/emulationstation/es_systems.cfg
              and copy it to this folder
              /home/pi/.emulationstation/
              This is a Symbolic link witch poinst to /opt/retropie/configs/all/emulationstation
              EmulationStation first checks in /home/pi/.emulationstation and then checks /etc/emulationstation
              • Edit es_systems.cfg to change the path to your mount point
              Example
                  <name>amstradcpc</name>
                  <fullname>Amstrad CPC</fullname>
                  <path>/home/pi/RetroPie/roms/amstradcpc</path>
              To
                  <path>/media/usbstorage/roms/amstradcpc</path>
              A good freeware program that handles big files and is easy to use is Notepad++
              Just do this
              • Search->Replace (Ctrl-H)
              Find What: /home/pi/RetroPie/
              Replace With: /media/usbstorage/
              This ensures that Emulationstation picks up your rom directory.
              If you install new themes or systems the file will not be overwritten.
              More info about ES_Sytems.cfg on the wiki here
              Edit
              Made some changes and added guide for es_systems.cfg.
              FBNeo rom filtering
              Mame2003 Arcade Bezels
              Fba Arcade Bezels
              Fba NeoGeo Bezels
              cyperghostC K 3 Replies Last reply Reply Quote 4
                cyperghost @Rion
                @Rion Hehe :) We want easy solutions :)
                +1 for your extended explanation and information about issues :D
                RionR mediamogulM 2 Replies Last reply Reply Quote 0
                • RionR
                  Rion @cyperghost
                  @cyperghost Thank you
                  I have probable missed something and i can make in a little bit more detailed regarding ES_Sytems.cfg..
                  FBNeo rom filtering
                  Fba Arcade Bezels
                  Fba NeoGeo Bezels
                    cyperghost @Rion
                    @Rion
                    Yes but it's really better to use the fstab-method :)
                    Just for maintaining and helping the forum members :)
                    I also use the symbolic link but I know about it's weaks.
                    And in your solution you may have to edit the es_system.cfgwhich isn't always a good deal... if you do not know what are you doing :) So the proper solution is @herb_fargus posted :)
                      mediamogul Global Moderator @cyperghost
                      @cyperghost said in Run ROMs from USB flash drive instead of microSD card - manual:
                      There are no easy solutions, only small actors. Personally, I use the fstab method, but I believe every solution has a drawback or two.
                        cyperghost @mediamogul
                        @mediamogul I think the easiest solution will be a setup within RetroPie which scans all connected drives and asks for the current roms place for every emulator that can be selected by joypad control :)
                          The ability to run roms off of external media is probably the most requested feature that doesn't have a gui solution of any kind. RecalBox handles this from Emulation Station, but even a terminal menu would be a welcome addition. The other side of the argument is that there are so many ways to achieve this that leaving up to the user's own personal preference might be best.
                            Kreibich @Rion
                            @Rion Thank you, this might be a safe, but hard way... anyway thanks for explanation... It would be great if this would be implemented in next RetroPie version as simple swith SD / USB.
                              cyperghost @Rion
                              @Rion said in Run ROMs from USB flash drive instead of microSD card - manual:
                              .... long posting :)
                              Rions' method got the big advantage to mount specific drives marked by an UUID.
                              So we can use several USB stick, HDDs.... whatever we want and every partition can be mounted seperatly. So we can use an old small USB stick for NES, SNES, Genesis Roms and we can use a big HDD with several GB to mount PSX, MAME, SCUMMVM and Dreamcast games for ex.
                              The big clue is the mount --bindcommand.
                              The content of USB stick1 can be mounted to a specific folder maybe /home/pi/retropie/roms
                              and also the content of HDD1 can also be mountend to same location :)... Without editing RetroPies config data (es_systems.cfg)
                              Sometimes automount and it's specific USB0, USB1 method can cause errors, because sometimes the devices responds differently. So the volume identification via UUID is a good deal :)
                              Thanks again rion for your entry.
                              RionR 1 Reply Last reply Reply Quote 1
                                Kreibich
                                For multiple flash drives in one folder you can also use mhddfs: https://romanrm.net/mhddfs
                                That is probably the best solution, how you can merge all folders in one.
                                cyperghostC 1 Reply Last reply Reply Quote 2
                                  cyperghost @Kreibich
                                  @Kreibich As you see there are several ways to solve one problem. But as I said some postings before...
                                  I suggest this thread as a infopool ;)
                                  • RionR
                                    Rion @cyperghost
                                    mount --bind should work.
                                    There is a Feature Request about it here
                                    Play games from USB [Feature Request] #1130
                                    FBNeo rom filtering
                                    Fba Arcade Bezels
                                    Fba NeoGeo Bezels
                                    • DarksaviorD
                                      Darksavior
                                      I just edit es_systems.cfg and make it point to /media/usb0/ done and done.
                                      It does get overwritten with updates so I back it up. I wonder if I can make it read-only.
                                        Kreibich
                                        Well, in my opinion mhddfs method is probably the best, because you don't care where the files are located. If there is no free space left on one device, it automatically switchs you to another and it looks still as one merged folder.
                                        • RionR
                                          Rion @Darksavior
                                          @Darksavior said in Run ROMs from USB flash drive instead of microSD card - manual:
                                          If you want to customise your es_systems.cfg or add themes without them being overwritten on updates you can add them to /home/pi/.emulationstation EmulationStation first checks in /home/pi/.emulationstation and then checks /etc/emulationstation.
                                          FBNeo rom filtering
                                          Fba Arcade Bezels
                                          Fba NeoGeo Bezels
                                          • RionR
                                            Rion @Kreibich
                                            @Kreibich said in Run ROMs from USB flash drive instead of microSD card - manual:
                                            I care where my files are located.
                                            But i agree to disagree. We all have our own preferences.
                                            FBNeo rom filtering
                                            Fba Arcade Bezels
                                            Fba NeoGeo Bezels
