    crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-fbalpha 029739 (formerly lr-fba-next)
    arcadeshadersfba
    22 Posts 5 Posters 11.6k Views
      red2blue @edmaul69
      @edmaul69
      you press CTRL+F
      press REPLACE tab
      type in the line you are searching for
      enter what you want replaced
      on the right you should see "REPLACE" and "REPLACE ALL"
      press replace all. make sure Match Case is checked Wrap Around is checked, Search mode "EXTENDED" is selected,
      • papinistP
        papinist
        Can someone reupload those overlays in second post? They aren't available anymore..
