    Any way to show TurboGrafx 16 instead of PC Engine?
    22 Posts 9 Posters 15.0k Views
      stevetb
      All:
      On my menu's I see PC Engine, is there any way in which I can have the platform listed instead as TurboGrafx 16?
      Thank you,
      Stevetb
      • herb_fargusH
        herb_fargus administrators
        change the theme tag in es_systems.cfg to tg16 instead of pcengine or rename the files in the theme itself
          stevetb
          Worked Great, thank you herb_fargus!
          Here are the details on how I did this in case others have the same issue:
          Go here and edit this file:
          Step 1 = cd /etc/emulationstation/es_systems.cfg
          Step 2 = sudo nano es_systems.cfg
          Step 3 = Go to the PCEngine section
          Step 4 = change <theme>pcengine</theme> to <theme>tg16</theme>
          Step 5 = Save then reboot
          Note: I also did this for MegaDrive and changed it to Genesis
          • herb_fargusH
            Just fyi you'll want to take note of this post: https://github.com/RetroPie/RetroPie-Setup/wiki/EmulationStation#my-es_sytemscfg-is-being-overwritten-on-updates it may be worth copying it over with sudo cp /etc/emulationstation/es_systems.cfg /home/pi/.emulationstation/es_systems.cfg but you'll have to manually update it anytime you add a new system
              Bunji
              Is there any way to have both available? I'd like to separate the PC Engine and Japanese versions from the TurboGrafx and North American versions.
              jonnykeshJ D 2 Replies Last reply Reply Quote 0
              • jonnykeshJ
                jonnykesh @Bunji
                @bunji 95% of what you need is already covered in this thread. Just copy the PC Engine setup and change one of those to TG-16 as per the instructions. Have that one point to a tg16 rom folder. Create tg16 rom folder. Put roms in.
                You'll also need to tweak your theme to add a tg16 system plus art.
                • E
                  edale
                  from the wiki:
                  If you want EmulationStation to show the TurboGrafx-16 graphics instead of PC Engine then you should create a file /opt/retropie/configs/all/platforms.cfg with the following contents (note this requires at least v4.1.6 of the RetroPie-Setup script).
                  pcengine_theme="tg16"
                  pcengine_platform="tg16"
                  Once this is done, please update any of the currently installed PC Engine emulators from RetroPie-Setup and Emulation Station will now use the TurboGrafx-16 logo. Scraping from within Emulation Station should also return TurboGrafx-16 artwork.
                  The code to put in that file for Genesis is:
                  megadrive_theme="genesis"
                  megadrive_platform="genesis"
                  Basically, create a blank .txt document, name it 'platforms.cfg' and type those 4 lines of text in them.
                  I have a copy of this file here: https://mega.nz/#!3RhhEYDD!IRPhwx3_naUylPOMKOs5wJ9MTQ36CE2jR29UfBbty64
                  And place that file in '/opt/retropie/configs/all/'
                  And then update your emulators for TG16 and Genesis, and it'll switch over.
                  This change will persist through updates, unlike the change you made.
                  As a bonus, the scraper will prioritize NA releases when you scrape a rom in the sections after doing this.
                  For PCE vs TG16 games, I just made a folder inside the TG16 section for each system.
                    dudleydes @Bunji
                    @bunji It would've been better to have to started a new topic as your request is not the same as the title of this thread.
                    To have both PC Engine and Turbografx appearing in ES, you may find the following useful:
                    https://retropie.org.uk/docs/Add-a-New-System-in-EmulationStation/
                      Agrajag @stevetb
                      @stevetb Just tried this approach (changing the theme tag name) and it didn't work for me to get Showcase to show Genesis and TG16 art.
                      YFZdudeY 1 Reply Last reply Reply Quote 0
                      • YFZdudeY
                        YFZdude @Agrajag
                        @agrajag
                        Did you update the emulators after you made the config change?
                        A 2 Replies Last reply Reply Quote 0
                          Agrajag @YFZdude
                          @yfzdude Looks like I missed a step. Great news! Now I just need to figure out which ones they use. Off to go check. Thanks!
                            Agrajag @YFZdude
                            @yfzdude Went in and found each of the emulators (under Manage Main Packages) one for Genesis (lr-genesis-plus-gx) and one for TurboGrafx-16 (lr -beetle-pce-fast), and updated both of them. Then I rebooted.
                            No change in Showcase.
                              mitu Global Moderator @Agrajag
                              @agrajag said in Any way to show TurboGrafx 16 instead of PC Engine?:
                              Post your platforms.cfg file, with the modifications you've made. Also, please make sure you're not using a custom es_systems.cfg, the modifications from platform.cfg are not applied there.
                                Agrajag @mitu
                                @mitu I followed the first few posts in this thread which specifically alter just es_systems.cfg.
                                It sounds like from your response that that's not good enough (any longer)?
                                I'll give the platforms file approach a shot tomorrow.
                                  A lot of things changed in 5 years. A reply from @edale shows the documented way of changing the theme/system name in current versions.
                                    Agrajag @mitu
                                    @mitu Mitu, well I completed the steps and still no love. I do have a slight hiccup I wanted to ask about.
                                    Here's the contents of my "platforms.cfg" file which is currently located in my /opt/retropie/configs/all folder:
                                    After I created this (via Filezilla while I happened to be outside ES at a command prompt) I then jumped into Retropie Setup without ES loaded and went to Manage Main Packages where I scrolled down to lr -beetle-pce-fast and lr-genesis-plus-gx. Neither had the option to Update (which struck me as odd). I chose the option to Reinstall both of them from Binary, which I assumed would be the same as updating them in the end. Then I restarted ES/Retropie and neither Mega Drive or PC Engine were different in Showcase.
                                    Thoughts?
                                      Thoughts?
                                        Agrajag @mitu
                                        @mitu Well, I thought you found the issue, but sadly, no luck.
                                        I checked my es_systems.cfg file and it was clean. no "tg16" or "genesis" entries. However, after rebooting I now note that they're back:
                                        <system>
                                        <name>pcengine</name>
                                        <fullname>PC Engine</fullname>
                                        <path>/home/pi/RetroPie/roms/pcengine</path>
                                        <extension>.7z .pce .ccd .chd .cue .zip .7Z .PCE .CCD .CHD .CUE .ZIP</extension>
                                        <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS pcengine %ROM%</command>
                                        <platform>tg16</platform>
                                        <theme>tg16</theme>
                                        </system>
                                        <system>
                                        <name>megadrive</name>
                                        <fullname>Sega Mega Drive</fullname>
                                        <path>/home/pi/RetroPie/roms/megadrive</path>
                                        <extension>.7z .smd .bin .gen .md .sg .zip .7Z .SMD .BIN .GEN .MD .SG .ZIP</extension>
                                        <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS megadrive %ROM%</command>
                                        <platform>genesis</platform>
                                        <theme>genesis</theme>
                                        </system>
                                        So, I'm assuming I have something else going on, or the changes to platforms.cfg makes these changes for me each session. However, Showcase still shows tabs and graphics for PC Engine and Sega Megadrive.
                                          Which file exactly ? What happens if you switch the theme to Carbon ?
                                            Agrajag @mitu
                                            @mitu The es_systems.cfg that I've checked (and that's being updated automatically) is in /etc/emulationstation
                                            When I switch to Carbon it still says PC Engine and Megadrive. Grrr.
