    ControlBlock Power Switch Issue
    controlblockpowerswitch
    26 Posts 7 Posters 7.2k Views
      Townsperson
      I just finished hooking up a ControlBlock to an RPi3. I have an inidicator LED wired up, as well as a toggle switch for power. Installed the software and everything seemed to go OK.
      Anyway, I have an issue with this where the switch will turn on my RPi, but won't shut it down. Also, the LED will light, but will remain flashing for as long as the system is booted. Any ideas?
      Also, quick thing to note, after installation of the ControlBlockService, I did not have config file at /etc/controlblockconfig.cfg. Ended up making the file and matching the default config.
        maudio
        UPDATE : Installing the "PowerBlock" git brings functionallity to the switch! On and Off switching works... but the ControlBlock itself not. There must be a script problem. Just installing it now again. Seems the git is updated now
        Same Problem here...
        Installed and Uninstalled ControlBlockService but nothing. I can switch the Rpi3 on but can't shut down. The LED is slowly fading all the time, no matter if the system is running or not.
        I have a ControlBlock V2.1 and just followed the manual at the Pet Rock Blog Site and also on github.
        If i check "service --status-all" , the ControlBlockService shows an "-" for not running. Manually starting the service dont work.
        Tested on RetroPie and Raspian Image
        My Config File was empty too, so i have copied the whole from github into it but still the same
        Googled around but no answer found.
          maudio
          @Townsperson : Have tested a little :)
          Just install ControlBlock1... after that install ControlBlock2.
          Now the switch work and the LED does it thing BUT no recognizing of buttons or something :(
            Townsperson @maudio
            @maudio
            Same thing here. I guess something is broken in ControlBlockService2. Hopefully it gets fixed at some point, but until then, at least the switch and LED are working.
            Thanks for the help.
              m312
              Yup same problem, ControlBlockService2 seems to not be working. Or controlblock 2.1....
              Thinking of just sending the control block back, unless someone can find out why, it isn't working for whatever reason.
                petrockblog Global Moderator
                There was a bug in the recent version of the driver. That is fixed now! Please pull the latest version of the driver and re-install it. Hope that helps!
                  RetroShark
                  I had the same issue, I finally got my RetroPie assembled after months of delay and ControlBlockService 2 would not start...at least would not look started from service --status-all. Glad to have found this message...updating to latest driver and will try.
                  pi@retropie:/var/log $ sudo service controlblockservice start
                  pi@retropie:/var/log $ sudo service controlblockservice status
                  ● controlblockservice.service - LSB: ControlBlockService init script
                  Loaded: loaded (/etc/init.d/controlblockservice)
                  Active: active (exited) since Tue 2017-01-17 03:47:38 UTC; 1s ago
                  Process: 9596 ExecStop=/etc/init.d/controlblockservice stop (code=exited, status=0/SUCCESS)
                  Process: 9634 ExecStart=/etc/init.d/controlblockservice start (code=exited, status=0/SUCCESS)
                  Jan 17 03:47:38 retropie systemd[1]: Started LSB: ControlBlockService init script.
                  pi@retropie:/var/log $ sudo service --status-all | grep controlblockservice
                  [ - ] controlblockservice
                  pi@retropie:/var/log $ tail -10 /var/log/syslog
                  Jan 17 03:45:10 retropie systemd[1]: Started LSB: ControlBlockService init script.
                  Jan 17 03:46:07 retropie wpa_supplicant[401]: wlan0: WPA: Group rekeying completed with 14:22:db:30:1f:46 [GTK=CCMP]
                  Jan 17 03:47:22 retropie systemd[1]: Stopping LSB: ControlBlockService init script...
                  Jan 17 03:47:22 retropie systemd[1]: Stopped LSB: ControlBlockService init script.
                  Jan 17 03:47:38 retropie systemd[1]: Starting LSB: ControlBlockService init script...
                    RetroShark
                    Ok, the latest version starts the service, however appears to ignore the powerswitchOn setting. It kept shutting down until I found a jumper and manually jumped the switch pins together. Not sure why (see config below).
                    Also /dev/input/js0 now works properly! It also creates a /dev/input/js1 despite not having any second controller connected. I thought the config below should disable this, but clearly not.
                    "controlblocks" : [
                    "enabled" : true, // Enables (=true) or disables (=false) the ControlBlock
                    "address" : { // The address information of the first ControlBlock
                    "SJ1" : 0, // The hardware address solder-jumper SJ1. Options: 0, 1
                    "SJ2" : 0 // The hardware address solder-jumper SJ2, Options: 0, 1
                    "gamepadtype" : "arcade", // Sets the gamepad type. Options: "arcade", "mame", "snes", "none"
                    "onlyOneGamepad" : true, // If true, registers only one gamepad instead of two
                    "powerswitchOn" : false // Enables (=true) the power switch functionality. Options: true, false
                    "enabled" : false, // Enables (=true) or disables (=false) the second ControlBlock
                    "address" : { // The address information of the second ControlBlock
                    "SJ1" : 1, // The hardware address solder-jumper SJ1. Options: 0, 1
                    "onlyOneGamepad" : true // If true, registers only one gamepad instead of two
                      The location of the configuration file has also changed with the recent driver update. It is now located at /usr/local/etc/controlblockservice.cfg.
                      I just retested the driver with the options you posted above. onlyOneGamepad and powerswitchOn are working as intended.
                        dantropie
                        The power switch on my control block was working fine. It would turn on then turn off quickly. But my buttons weren't working. So I reinstalled everything and my buttons are working now. However now when I turn off the power switch it blinks for a long time. Almost 4 min before shutting down. Anyone have any ideas?
                          dantropie @dantropie
                          @dantropie correction, it takes 3 min. I feel it used to take like 20 seconds before. And it opens a command line saying "the system is going down to power off at date n time" or something like that. It repeats that 3x hen shuts off in 3 min. Any help would be appreciated.
                          I checked the config file and powerswitch is set to true
                            BakedGoods @dantropie
                            @dantropie said in ControlBlock Power Switch Issue:
                            I'm having the exact same issue, it broadcasts a message that in 3 minutes it will power off, then it does. I'm actually fine with the delay but I'm concerned it's just stopping power to the raspberry pi rather than properly shutting down linux.
                            I'm using the PowerBlock and I installed the latest driver (as of today) by following the blog's directions (ie. "git clone git://github.com..." etc.) How do I check the version number?
                            Any help?
                              m312
                              Same problem, not sure mine even powers off, but I'm fine with that, no accidental shut downs. I can power up fine with the button and shut down with ES, so might not change it even if there's a fix.
                                dantropie @m312
                                @m312 that's defeats the purpose of adding a switch tho. Sigh
                                  m312 @dantropie
                                  @dantropie Yeah sure, it should be fixed, but for me personally, I don't mind as switching on was the thing I wanted it for anyway
                                    m312 @BakedGoods
                                    @BakedGoods
                                    Try:
                                    git clone https://github.com/petrockblog/PowerBlock.git instead
                                    the https made the difference with the Controlblock (which wasn't working at all before)
                                    D B 2 Replies Last reply Reply Quote 0
                                      dantropie @m312
                                      @m312 yea you're right. i guess i can quit thru ES, but sometimes it's nice to just be able to press the button from anywhere in the game. i also have a main switch for the main system (pi, monitor, marquee light, and speakers) so i guess i dont really need a switch for the power.
                                      ALso, i installed mine with the https, but still have the issue so dont think it's that. It did however make the buttons work.
                                      hopefully a fix is made.
                                        BakedGoods @m312
                                        @m312
                                        Hey thanks for the tip. I uninstalled then re-installed with that link and the issue remains.
                                        I mean it's not a huge deal, it does shut off, just takes 3 minutes. Kind of a quirky bug.
                                          @dantropie @m312
                                          Hey so I (think?) I've got it fixed.
                                          I uninstalled the service, went into the actual src files ("/root/PowerBlock/src/powerblock/") and edited line 54 of PowerSwitch.cpp to instead of say "shutdown -t 3 -h now" it's set to "shutdown -h now". I reinstalled the service and rebooted--works! Shuts down in about 30 seconds, I see the verbose shutdown, and no echo warning. I have no LED set up so I'm not sure how that responds.
                                          So maybe not a bug but a deliberate 3 minute timer on shutdown? Not sure why.
                                            Thanks for the heads up. I will release a version with a fix for that during this day!
