    Attract Mode help retro pie 4.2
    attract mode
    3 Posts 2 Posters 1.3k Views
    • E
      evarcade85
      Hey, first time posting so "HI"
      I have updated retro pie to ver 4.2 and downloaded the attract mode, what do I do next? Is there a way to access it in the menu or do you still have to type attact in the script.
      Thank you in advance,
        A Former User
        Welcome to the forums!
        I had the same question, and I tried it. You have to go to the command line (press f4 to exit EmulationStation) and type in attract or attract-mode. I forgot which one it was.
        There is a post on here that lets you create an option in the RetroPie menu to restart in Attract Mode, like Floob's image, but it does require a little coding in.
        • E
          evarcade85
          Yea thats what I was going to do but I was wondering if there was something else now that it has been included with 4.2 So I was holding off just incase there was a easier way.
