    Using 1P and 2P Joysticks for P1 in Mame?
    22 Posts 4 Posters 10.2k Views
      jimd0586
      @Floob and anyone else generally:
      Is it possible to setup MAME in retropie to use the P1 and P2 joysticks for controlling player 1? I have an arcade layout with P1 and P2. I'd prefer to use it than to plug in a PS4 controller or something similar.
      Thinking Robotron here where one joystick controls movement and the other controls your shooting. Anyway to set it so both joysticks work together for P1?
      Thanks guys. Using buttons to shoot just isn't the same thing.
      RiverstormR FloobF 2 Replies Last reply Reply Quote 0
      • RiverstormR
        Riverstorm @jimd0586
        @jimd0586 said in Using 1P and 2P Joysticks for P1 in Mame?:
        I don't have a setup like that but I think that should be configurable. Press "TAB" (while in game), then "Input (this game)" and configure the directional fire buttons to use the other joystick.
          mediamogul Global Moderator @Riverstorm
          @Riverstorm said in [Using 1P and 2P Joysticks for P1 in Mame?](/topic/972/using-1p-and-2p-joysticks-for-p1-in-mame
          Press TAB (in game), then Input (this game) and configure the directional fire buttons to use the other joystick.
          I set up Robotron 2084 on my own arcade cabinet using this exact method and can confirm it plays very well. Tons o' fun!
            jimd0586
            @mediamogul @Riverstorm
            Nice! Ok, so use a keyboard to set it up for specific in-game configurations specific to that game.
            Then I am guessing you adjust Fire Up, Fire down, fire left, and fire right and just move the P2 Joystick in the correct direction to have that become the new fire control? It's that simple?
            • RiverstormR
              Yes sir, it's that simple! :) You can leave the original values in place so you can use both the buttons and joystick too if you want. Also it works quite well on controllers like the XBOX or PS with dual analog sticks.
              • FloobF
                Floob @jimd0586
                @jimd0586 When you say "MAME", which emulator are you using?
                https://github.com/RetroPie/RetroPie-Setup/wiki/Managing-ROMs
                Yes, as replies above say, shouldnt be an issue.
                  jimd0586
                  Mame libretro I think. I have had the most success running roms with that emulator.
                  • RiverstormR
                    Riverstorm @Floob
                    @Floob said in Using 1P and 2P Joysticks for P1 in Mame?:
                    I thought about that Floob and then thought it shouldn't matter? It should be ok regardless of the version as the TAB key works in all version of MAME standalone and Libretro? Or would it overwrite something depending on the "hierarchy" of settings?
                      jimd0586
                      @Floob @Riverstorm
                      So, I just got home and tried out setting specific game inputs. The menu isn't really responding well to keystones or button inputs. I bring up the menu, I can access exactly what I want, but when I the input I want to remap when I click that button or move the joystick its like it isn't read.
                      I do know the joysticks work because: 1) 2 player works on games, and 2) because I did get the joystick to be read for one input but in trying to find out why it wasn't working i had mapped it the wrong direction.
                      Any reason why the mapping in MAME for a specific game isn't working? Am I doing something wrong?
                        jimd0586
                        @Floob @Riverstorm
                        I seem to always have problems with my controllers!!!! ARGHHH. I swear I got it to work once, albeit incorrectly. It's as though the system doesn't register an input being inserted. However, it won't work for P1 controls either. Like I said, it's as though the emulator isn't registering key strokes.
                        I will add that sometimes I will punch in a number of keys or directions and then a black box appears and reads like "No Button A, Button X, Retread 1 Down,..."
                        What the heck? "No"?
                          jimd0586
                          figured it out, i wasn't holding the button down long enough when mapping!
                          • RiverstormR
                            Great! It's good to see it working.
                            I don't know if it's applicable at all but when I was running under powered my Pi buttons seemed to lag a little in responding to key presses or I had to press them multiple times. It's not always the power supply though sometimes a cheap cable or a long cable can cause a power issue even with a beefy power supply. If you do you'll see a small colored square in the upper right hand corner. Both cause turbo mode to be shut down.
                            Red square = over-temperature
                            Rainbow square = under-voltage
                            You can override the warnings but there are risks obviously.
                            Add these lines to your /boot/config.txt
                            Removes the overlay warnings:
                            avoid_warnings=1
                            Allows turbo even when low-voltage is present:
                            avoid_warnings=2
                              jimd0586
                              I was just gonna ask about that... I added a USB powered light strip to light my marquee. I knew it would draw power but now I'm seeing that rainbow square more often. I also noticed that MAME Sunset Riders is even slowing down a bit... I have the pi3 overclocked to 1350(as high as I could get and run stable). Should I reduce fps or resolution for my emulators or should I unplug the light strip?
                              I think unplugging the strip might help but ultimately I still have slowdowns in some games regardless. Any tips to get slower games and emulators to run better?
                              N64 is a good example, but some other emulators like MAME and FBA still lag a bit.
                              Any help appreciated. @Floob @Riverstorm
                              • RiverstormR
                                I think Floob is more versed in these matters than I am as a lot of what I learn is from his videos. :) You could try some tweaks and see what kind of results you get but ultimately I would focus on your power supply to make sure it's within specs. I don't know but would be hesitant if changing FPS or lowering resolution would reduce the power draw.
                                Overclocking itself does use more power and the more USB ports you have populated the more power you need.
                                I had an issue where I had a quality power supply but I was using a 10' USB cable that was causing some vdroop so that might be worth looking into also.
                                My Pi 3 is stable at 1300. I thought it was stable at 1350 until I started using more cores while compiling and that's when it started locking up so I bumped it back down to 1300. The reason you don't see crashes/freezes as often in emulation is usually they are running on a single core. Running at 1300 I was able to drop my overvolt to 4 which helped a bit with power consumption.
                                If it fits in your budget I think I would invest in a higher amperage/voltage power supply and check your power cable to verify it is using a quality gauge wire.
                                  jimd0586
                                  @Riverstorm
                                  Thanks. Any idea what kind of power supply I can use?
                                  I'll drop my OC to 1300.
                                  I just recall a video that showed N64 running slowly on the pi and that you had to reduce the resolution or something to get it to run properly.
                                  • RiverstormR
                                    @Riverstorm
                                    I would think any of the reputable Pi re-sellers would be sufficient. I buy a lot of stuff from MCM Electronics and Adafruit. Really there are several places.
                                    You might be fine at 1350, even 1400, every Pi is different so definitely experiment with that overclock.
                                    The resolution you're talking about is probably 640x480. Here's a thread by @Twitch0815 with some great info on the N64. It also has a Wiki link he created with suggested overclock settings to try.
                                    https://retropie.org.uk/forum/topic/140/how-to-use-overclock-and-mupen-core-options-to-significantly-increase-64-game-playability-quality-and-stability
                                      jimd0586
                                      @Riverstorm
                                      Boy, my existing power supply came from an ebay kit. I am pretty sure it is supplying enough juice. Is there a way to find out if the power usage/consumption/supply is the issue?
                                      • RiverstormR
                                        @Riverstorm
                                        Do you have the specs? On the power supply itself you'll see something like 2.5A 5.25V. It should have the information on it.
                                          jimd0586
                                          @Riverstorm
                                          Output: 5.0V ---2.5A
                                          It came in a kit.
                                          • RiverstormR
                                            @Riverstorm
                                            It came in a kit.
                                            It sounds sufficient. Who's the manufacturer? You might need a slightly higher voltage.
                                            This is getting out of the area I can help with. Running that lighted marquee with USB 2.0 for power. A unit load is defined as 100mA. A device may draw a maximum of 5 unit loads (500 mA) from a port. I think there's some wiggle room there so some manufacturers may go out of spec and pull a higher maximum current but you might need to play around a little.
                                            If you're seeing issues with the marquee unplugged then you need to keep removing things and remove overclocking altogether until it stops. Then start adding things. I still suspect the power supply or possibly the cable but maybe you're getting some overdraw with the marquee. I would play around with it a bit the answer has to be there. :)
