    z-index support for themes
    themezindex
    34 Posts 10 Posters 15.3k Views
      jdrassa @duiz
      @duiz said in z-index support for themes:
      @jdrassa I noticed that the Herdinger branch of ES has a hide game feature. Would it be possible to implement this into your z index branch release?
      https://github.com/Herdinger/EmulationStation/commit/196d9175c38da86f778e6a1af4fc8abb09270eea
      This branch is only intended for testing the z-index feature before it is merged into the RetroPie repository. I believe @Zigurana is planning on implementing hidden games here.
      Get latest build of EmulationStation for Windows here
      S ruckageR 2 Replies Last reply Reply Quote 1
        Syhles @jdrassa
        @jdrassa
        Saw your PR on the Retropie GitHub when I woke up, looking forward to it going through. I have been following this thread since it started.
        Quick question slightly unrelated to this, after this PR goes through are you going back to working​ on variable support or something else?
          SuperSirLink @jdrassa
          @jdrassa said in z-index support for themes:
          @SuperSirLink Sorry for the delayed response. I have been out of town and away from my computer. I am not sure the exact path, but you can add this script to RetroPie-Setup/scriptmodules/supplementary and then you will be able to install it using RetroPie-Setup. It should appear in the experimental section.
          No worries... Life had pulled me a way too onto other things... Cool, thanks for that! It is installing now, thanks again!
          • ruckageR
            ruckage @jdrassa
            @jdrassa
            Only just discovered this thread and first of all I have to say this is a great addition, zdepth is something that I've wanted in ES since I first began using it - it opens up so many new possibilities. Thank you for all you work.
            Now I do have a problem and haven't seen it mentioned here so thought I would ask. Currently I'm only experimenting with this on Windows but I'm getting a bug where if you fast scroll through the gamelist in detailed view then dark boxes appear on the screen - one covers the description text entirely (though the text can still be seen) and also some random smaller boxes in the gamelist itself. In debug mode a reload fixes it but it then happens again if you fast-scroll.
            Not sure if it's a known issue or something specific to the windows build but thought I should mention it.
              Syhles @ruckage
              @ruckage
              This has been fixed in a update a few days to a week ago on the source build.
              Not sure if it made it to the windows build yet, they've been rapid firing updates for about a week.
              Here's ​the GitHub
              https://github.com/RetroPie/EmulationStation/pulls
              ruckageR 1 Reply Last reply Reply Quote 1
              • ruckageR
                ruckage @Syhles
                @Syhles
                Thanks, that's good to hear. I just downloaded the Windows build today so I guess it's not up to date but as long as I know it's fixed on retropie then it's not a problem.
                • alphatoanantA
                  alphatoanant
                  Hi @jdrassa I found time to work on the other use case I mentioned above and have run into a snag.
                  It may not be z-index related. That said it does seem to be related to layering so I was wondering if you could take a look and help point me in the right direction.
                  Some background:
                  I am working on a theme for small screens (320x240 res) and had an idea to build a theme that looks like this:
                  See the image on the right of the view?
                  The idea there is to allow a user to scrape screenshots for each game normally without any additional cropping
                  In order to achieve that look the md_image essentially hangs off the right side of the view like this:
                  (green is what is visible in the view / red is what is positioned to be hidden outside)
                  The snag:
                  In testing, I have found cases where the image from one view will kind of "pop" into place on the view next to it. And when that happens the image sits on top of the gamelist itself.
                  It's much easier to see in video form so I recorded this to walk through it:
                  I have tried a few different things (reordering my elements, working with different z-index values) but unfortunately haven't be able to find something that works consistently.
                  Of note is I haven't found this behavior when showing video in place of the image.
                  I uploaded a version of the theme here if it helps to see the structure:
                  https://github.com/anthonycaccese/es-theme-crt-tft
                  Any help or guidance you have would be awesome. I also completely understand if this is out of scope and better asked somewhere else. Please let me know either way and thank you for your help.
                  My RetroPie Themes:
                  Art Book https://github.com/anthonycaccese/es-theme-art-book
                  Art Book Next https://github.com/anthonycaccese/art-book-next-retropie
                  TFT https://github.com/anthonycaccese/es-theme-tft
                  ruckageR J 2 Replies Last reply Reply Quote 0
                  • ruckageR
                    ruckage @alphatoanant
                    @alphatoanant
                    Hi,
                    Do you specifically want the left side of the screenshot displayed? If not you could use the new z indexing to draw the scraped image filling the entire screen and then draw everything else on top of that- no overhang needed.
                      jdrassa @alphatoanant
                      @alphatoanant I will look into it. I have a few ideas on how to fix it.
                      • alphatoanantA
                        alphatoanant
                        Thank you @jdrassa, if there is any other info I can help provide don't hesitate to let me know.
                        @ruckage, thank you for the suggestion! I may take a crack at that (possibly shift the image display to the left side of the view and the gamelist to the right as an alternative). Anecdotally from the set of images I checked most of them just look better shown from the left side of the screenshot =). That said checking some of the resolutions there is, unfortunately, still some chance for overhang into the next view. I am aiming to fill the height of the screen and some systems screenshots sized up to a 240 height extend a bit past 320 width (genesis and gba specifically). More to try - possibly making the image a strict 1x1 size and see if the distortion looks weird. My ideal state would be to see if there is a fix for the above though (it could give us more options for theming)
                        My RetroPie Themes:
                          @alphatoanant This should be fixed if you update EmulationStation.
                          alphatoanantA 1 Reply Last reply Reply Quote 1
                          • alphatoanantA
                            alphatoanant @jdrassa
                            @jdrassa thank you! It's working perfectly. Very awesome and much appreciated. Will try to finish up work on the next iteration of the theme by end of weekend. Cheers.
                            My RetroPie Themes:
                              pablosbrain
                              How or Can zIndex be used with other elements that aren't images?
                              <helpsystem name="help">
                              <textlist name="gamelist">
                              Those are a couple of the items i am trying to use it with, but it fails.
                                pablosbrain
                                Nevermind... Figured out i can do negative zIndexs on the images to put them below everything else.
